clinresga
- 2
Egg Launch and Recover--I need NASA level help!
Another variation on the classic Egg Launch and Egg Drop Science projects, only this 9th grade science teacher believes in upping the ante. Goals are to launch a raw egg, achieving at least 30 feet of vertical height, using a parabolic flight path (i.e. not just straight up), and then having the egg land intact. Combining these two problems seems almost insurmountable to us (my son and I).
Additional constraints: launcher must be a compound machine (uses at least two simple machines). No catching or landing pad devices: all egg protection must travel with the egg during the entire flight.
The usual motion equations, but this is really an engineering problem--they are not asking for any mathematical modelling.
OK, this is where we are to date. As far as I can tell, the simplest launcher design, a slingshot, is not eligible (not a "compound machine"). Similar problems with propelled devices like a water rocket, which would work well I suspect. No rockets.
We are looking at a Trebuchet made out of PVC pipe (I suspect y'all know what a Trebuchet is, but it is a catapult like device that uses a heavy counterweight to throw the arm). I think I can scale it up to the point where it would throw hard enough--but that's absent the real challenge in my mind, which is egg protection.
I'd love to use a parachute, but I cannot get past the deployment problem. I just don't think there is any reasonable way to reliably deploy a parachute. You'd have to use some kind of rocket like device with fins and a nose cone to do this, and that would be near impossible to launch with a Trebuchet.
So we are thinking of a protective device. Here, another problem. The bigger, and more protective the device, the harder it will be to throw 30 feet up. So our working idea is to construct an open wire cage, to minimize air resistance, and then suspend the egg inside. Twisted pantyhose appears to be the simplest material to suspend egg, though we might fool around rubber bands.
OK: is this desperately stupid? Does anyone have a (preferably much simpler) suggestion? This is TOUGH! (unless I'm missing some "Gotcha" trick to solve this).
Thanks!
Thanks!
