Eigenenergy of triangular molecule
In summary, the eigenenergy of a triangular molecule refers to the quantized energy levels associated with its quantum states. These energy levels arise from the molecular structure and the interactions between its constituent atoms or electrons. The triangular geometry influences the symmetry and resulting energy eigenvalues, which can be calculated using quantum mechanical models. Understanding the eigenenergy is crucial for predicting molecular behavior, reactivity, and spectral properties in various chemical and physical contexts.
physicsxanime
See the screenshot next
Eigenenergy E is ##\hat{H}\psi = E\psi##
electron is fermion, so it should be antisymmetrized
I am preparing for graduate prelim exam:
My attempt is that, I have three sites for each of the electron to be at, each of them are 1s orbital. Also, electron has a spin 1/2. So, I think the Hilbert space would be quite large, I have state of both electron on each site 1, 2, 3 with singlet spins. Then there are 3 more state of electron occupying a different site. My confusion here is then, since both electrons are in s state, they are in symmetric state, which forces the spin to be in singlet which is anti-symmetric. Then how do I get the triplet state energy? Also the Hilbert space is now size of 6, How am I diagonalizing 6x6 matric?
B is to add a U term in the diagonals of singlet state, which is the electron on same site?This would split the eigenenergy?
Since A says to neglect Coulomb repulsion, start with finding the eigenstates of a single electron, then you can put the two electrons in these eigenstates while taking care of building anti-symmetric states.
Likes physicsxanime
Yes, of course. I am just stupid. Let's shift the energy scale so that the atomic energy at 1s is 0.
Then the Hamiltonian is
\begin{pmatrix}
0 & 1 & 1\\
1 & 0 & 1\\
1 & 1 & 0
\end{pmatrix}
The eigenenergies and corresponding eigenvectors are ##\lambda_1 = -1##, ##\lambda_2 = -1##, ##\lambda_3 = 2##, ##v_1 = (-1,0,1)^T##, ##v_2 = (-1,1,0)^T##, ##v_3 = (1,1,1)^T##
Note that ##v_1## and ##v_2## are anti-symmetric while ##v_3## is symmetric.
Therefore, the singlet state is paired up with symmetric state and the lowest eigenvalue is using ##v_1## and ##v_2## or any linear combination of the two on each of the electrons. So this state has eigen value of -2.
Whereas the triplet state is aired up with antisymmetric state and the lowest eigenvalue is using ##v_1## and ##v_2## or any linear combination on one electron and the other one using ##v_3##. Hence, the eigenvalue is 1.
B, hmmm, only some of the singlet state is having large splitting. But anyway, one can use degenerate perturbation theory to prove the assertion, the correction must be of order ##U##, so we know there is a large splitting without doing the calculation. And the large splitting is from singlet state forcing a symmetric spatial state and hence gaining U by putting them on the same site.
FAQ: Eigenenergy of triangular molecule
What is eigenenergy in the context of a triangular molecule?
Eigenenergy refers to the specific energy levels associated with the quantum states of a system, such as a triangular molecule. In quantum mechanics, these energy levels are determined by solving the Schrödinger equation for the molecule, which describes how the wave function of the system evolves. Each eigenenergy corresponds to a particular eigenstate, and these states are quantized, meaning they can only take on discrete values.
How do you calculate the eigenenergy of a triangular molecule?
To calculate the eigenenergy of a triangular molecule, one typically employs quantum mechanical methods such as the Schrödinger equation. For simple systems, analytical solutions may be possible, but for more complex molecules, numerical methods like the Hartree-Fock method or Density Functional Theory (DFT) are often used. The process involves setting up the Hamiltonian operator that represents the total energy of the system and then finding its eigenvalues, which correspond to the eigenenergies.
What factors influence the eigenenergy of a triangular molecule?
The eigenenergy of a triangular molecule can be influenced by several factors, including the molecular geometry, the types of atoms involved, the electronic configuration, and the presence of external fields (such as electric or magnetic fields). Additionally, interactions between electrons, such as electron-electron repulsion, and the effects of molecular vibrations can also affect the eigenenergies.
What is the significance of eigenenergies in molecular spectroscopy?
Eigenenergies are crucial in molecular spectroscopy because they determine the allowed energy transitions between different quantum states of a molecule. When a molecule absorbs or emits light, it does so by transitioning between these energy levels. The differences in eigenenergies correspond to the wavelengths of light that are absorbed or emitted, allowing scientists to identify molecular structures and understand their properties through spectroscopic techniques.
Can eigenenergy calculations predict molecular stability?
Yes, eigenenergy calculations can provide insights into molecular stability. Generally, lower eigenenergies correspond to more stable configurations of a molecule, while higher eigenenergies may indicate less stable or excited states. By analyzing the eigenenergies of different configurations, researchers can predict which molecular structures are more stable and likely to exist under given conditions.
