Eigenfunction boundary conditions order
In summary, the order of solutions v and u does not matter in this case with the eigenfunction boundary condition. Also, p(x) is commonly represented as P(x) in ODEs, where P(x) is the ratio of coefficients p1(x) and p0(x). This notation is used to simplify the representation of the problem.
ognik
643
Hi, just want to confirm that with the eigenfunction boundary condition $ p(x) v^*(x)u'(x)|_{x=a} = 0 $, the order of (solutions) v, u doesn't matter? I ask because a problem like this had one solution = a constant, so making that the u solution makes $ p(x) v^*(x)u'(x) = 0 $ no matter the limits...
Also checking that p(x) is what I think of as $ P(x) = \frac{p_1(x)}{p_0(x)} $ ? (for ODE's)
Hello,
Yes, the order of solutions v and u does not matter in this case. The eigenfunction boundary condition only requires that the product of the solutions v and u satisfies the given condition, regardless of their order.
As for your second question, yes, p(x) is often represented as P(x) in ODEs, where P(x) is the ratio of the coefficients p1(x) and p0(x). This is a common notation used in ODEs to simplify the representation of the problem.
I hope this helps clarify your doubts. Let me know if you have any further questions.
FAQ: Eigenfunction boundary conditions order
1. What are eigenfunction boundary conditions?
Eigenfunction boundary conditions refer to the conditions that must be satisfied at the boundaries of a system in order for a specific set of functions, called eigenfunctions, to be a solution to the system's differential equations.
2. What is the order of eigenfunction boundary conditions?
The order of eigenfunction boundary conditions refers to the number of derivatives that appear in the boundary conditions. For example, if the boundary conditions involve the first derivative of the eigenfunctions, then the order would be 1.
3. Why are eigenfunction boundary conditions important?
Eigenfunction boundary conditions are important because they allow us to find specific solutions to differential equations that satisfy the given boundary conditions. These solutions can then be used to model and understand various physical and mathematical systems.
4. How do eigenfunction boundary conditions differ from initial value conditions?
Eigenfunction boundary conditions are conditions that must be satisfied at the boundaries of a system, while initial value conditions are conditions that must be satisfied at a specific starting point within the system. In other words, eigenfunction boundary conditions determine the solution at the boundaries, while initial value conditions determine the solution at a specific point within the system.
5. Can eigenfunction boundary conditions be applied to all types of systems?
Eigenfunction boundary conditions can only be applied to certain types of systems, specifically those that can be described by differential equations. These systems must also have well-defined boundaries in order for eigenfunction boundary conditions to be applicable.
