Eigenfunction & Potential Barrier
In summary, the given solution provides the general forms of the allowed eigenfunctions in each region in terms of unknown constants A, B, C, D, F, and G. The term Gexp(-ikx) in region III represents a particle traveling to the left, which must be zero given the incident particle is traveling from left to right. The terms C and D represent exponentially growing or damping terms inside the barrier due to the barrier height being greater than the total energy of the particle.
ZedCar
354
A particle of total energy E is incident on a potential barrier V0 (E<V0) between x=0 and x=a. Write down the allowed eigenfunctions in the regions x<0, 0<x<a and x>a in terms of five unknown constants A, B, C, D and F where A and F are the amplitudes of the incident and transmitted eigenfunctions.
The solution as provided with this question is as below, though you'll notice it uses A, B, C, D, F & G. So either the question mistakenly excluded 'G' or there is some error in the provided solution.
ψI = Aexp(ikx) + Bexp(-ikx)
ψII = Cexp(αx) + Dexp(-αx)
ψIII = Fexp(ikx) + Gexp(-ikx)
If the solution provided above is correct, is 'G' therefore the amplitude of the transmitted eigenfunction, not 'F' as stated in the question?
The solution gives the general form of the solution of the Schrodinger equation for each region. If you then invoke the additional information that the particle is incident on the barrier traveling from left to right, you should be able to argue that G must be zero.
Thanks TSny.
From further advice I have been able to obtain I believe you are correct in stating that G must be zero.
May I ask how can it be deduced that G must be zero?
What exactly is it that the G represents that is zero?
Does the term Gexp(-ikx) represent a particle traveling to the right or to the left?
If the particle makes it to region III, which direction would it have to be traveling?
From the way your question is worded I'm guessing the term Gexp(-ikx) represents a particle traveling to the left. Hence the reason it equals zero.
If this is correct, does this mean that the first term in each expression, ie A, C, F represents the particle moving to the right, and the second term in each expression ie B, D, G represents the particle moving to the left?
To the right.
Yes.
That's true for A, B, F, and G. However, the C and D terms are exponentially growing or damping terms that do not correspond to traveling waves.
And for C and D, do you know these are exponential growing/damping terms, and not a traveling wave, because they are inside the barrier?
They are exponentially growing/damping because the arguments of the exponentials do not have a factor of ##i##. And this is due to the fact that inside the barrier, the barrier height is greater than the total energy of the particle.
Thanks very much for that TSny.
Related to Eigenfunction & Potential Barrier
1. What is an eigenfunction?
An eigenfunction is a mathematical function that satisfies a specific type of equation, called an eigenvalue equation. It represents the unique solution to the equation and is associated with a particular eigenvalue. In quantum mechanics, eigenfunctions are used to describe the energy states of a system.
2. What is a potential barrier?
A potential barrier is a region in space where the potential energy of a particle is higher than its kinetic energy, resulting in a barrier that the particle must overcome to move through the region. This can be seen as a hill that a particle must climb in order to continue its motion.
3. How are eigenfunctions and potential barriers related?
Eigenfunctions can be used to describe the behavior of particles in the presence of a potential barrier. The eigenfunctions represent the energy states of the particles, and the potential barrier affects the potential energy of the particles. By solving the eigenvalue equation, we can determine the allowed energy levels and the corresponding wavefunctions of the system.
4. What is the significance of the eigenvalues in relation to potential barriers?
The eigenvalues in the context of potential barriers represent the energy levels that a particle can have while moving through the barrier. These energy levels determine the behavior of the particle, such as its ability to tunnel through the barrier or be reflected back.
5. Can eigenfunctions and potential barriers be applied to other fields besides quantum mechanics?
Yes, eigenfunctions and potential barriers have applications in many areas of science and mathematics. They are used in fields such as signal processing, fluid dynamics, and acoustics to describe the behavior of waves and particles in different systems. They also have applications in solving differential equations and analyzing data in various fields.
  • Quantum Physics
