Eigenfunctions, eigenstates and eigenvalues
In summary, the conversation discusses finding the x dependence of the function ψ(x) as x increases by b, 2b, etc. The problem statement introduces A_hat=exp(b*(d/dx)) and states that ψ(x) is an eigenstate of A_hat with eigenvalue λ. The conversation then goes on to discuss writing out the eigenvalue equation and using LaTeX to properly format equations. Eventually, the individual comes to a solution, understanding how to incorporate the eigenvalue equation and the role of LaTeX in presenting equations.
Harper
The problem states consider A_hat=exp(b*(d/dx)). Then says ψ(x) is an eigenstate of A_hat with eigenvalue λ, then what kind of x dependence does the function ψ(x) have as x increases by b,2b,...?
Started out by doing (A_hat)ψ(x+b), turned that into (A_hat)ψ(x)+(A_hat)ψ(b). Not sure where to go from there and/or how to incorporate λ.
Did you write out the eigenvalue equation?
Note: you are asked what happens with ##\psi(x)\to\psi(x+nb): n=1,2,3,\cdots##
ie - how does ##\psi## depend on ##x##?
Do I read this correctly: ##\hat A = e^{b\frac{d}{dx}}## ??
Likes Harper
Yes you read it correctly and no I didn't write that out.
Hey thanks for the tool and I think I have it figured out. Thank you for the help.
Well done - what did you figure out (just for other people stuck on the same thing...)?
Related to Eigenfunctions, eigenstates and eigenvalues
1. What are eigenfunctions?
Eigenfunctions are functions that, when operated on by a linear operator, return a constant multiple of the original function. In other words, the function is unchanged except for a scaling factor.
2. What are eigenstates?
Eigenstates are the quantum mechanical equivalent of eigenfunctions. They are the states of a system that, when measured, give a definite value for a physical property (such as energy) with a corresponding eigenvalue.
3. What are eigenvalues?
Eigenvalues are the constants by which an eigenfunction is scaled when operated on by a linear operator. In quantum mechanics, they correspond to the measurable values of physical properties that are obtained when the system is in a specific eigenstate.
4. Why are eigenfunctions, eigenstates, and eigenvalues important?
Eigenfunctions, eigenstates, and eigenvalues are important concepts in quantum mechanics because they provide a mathematical framework for understanding and predicting the behavior of quantum systems. They allow us to calculate the probabilities of different outcomes in experiments, and they form the basis for many important quantum mechanical principles and equations.
5. How are eigenfunctions, eigenstates, and eigenvalues used in real-world applications?
Eigenfunctions, eigenstates, and eigenvalues are used in a wide range of real-world applications, such as in quantum computing, spectroscopy, and materials science. They are also used in many mathematical and scientific fields outside of quantum mechanics, such as signal processing and differential equations, to describe the behavior of systems and phenomena.
