Eigenstates, Eigenblahs, and Eigenpoofs? HELP O.O
In summary, the OP is an expert in math, linear algebra, and differential equations. They are starting to learn quantum mechanics and are having a bit of trouble understanding what an eigenvalue and eigenfunction is. They are unsure if what they understand is correct. They are a senior in high school and are going to college as a freshman this fall. They will need to be aware of spin when they start discussing particles in their book.
Domnu
178
Okay, so here's my knowledge of quantum mechanics: *crickets chirping in the background*. Here's my mathematical knowledge: basic integral calculus, some multivariable calculus, decent amount of linear algebra (knowledge of subspaces, projections, eigenvalues of matrices, eigenvectors, etc.), a decent amount of diff. eqs (not PDEs, though), all of high school math (extremely well... I was like 3 points of the usamo this year).
So anyways, I started learning quantum mechanics like a week ago, and pretty much have learned:
the construction of the Schrodinger equation (time dependant and independant)
the overall concept of a Hermitian operator
the infinite well situation
and that's about it.
I have been running into the words: eigenvalues, eigenfunctions, and eigenstates many times. I am pretty sure I understand what an eigenvalue and eigenfunction is, but I'm a bit shaky on what an eigenstate is. Just to clarify, in the equation
[tex]
\hat{A}\psi = a \psi
[/tex]
for some [tex]a[/tex], we have that [tex]\psi[/tex] is an eigenfunction (which could be vector-valued?) of [tex]\hat{A}[/tex] and [tex]a[/tex] is an eigenvalue of [tex]\hat{A}[/tex]. Is this correct?
If relevant or helpful at all, I am currently a senior in high school who is going to enter college as a freshman this coming fall.
[tex]
[/tex]
Yes, it is. The "which could be vector-valued" comment might be an indication that you have misunderstood one thing though. If you define the sum of two functions by (f+g)(x)=f(x)+g(x) and the product of a number and a function by (af)(x)=af(x), then you have turned the set of all functions into a vector space. My point is that it's not the values that the functions take that are vectors. The functions are the vectors, according to the definition of a vector space. The functions you encounter in quantum mechanics are going to be complex-valued functions of 1-3 real variables.
Yes, by this I meant that [tex]\psi[/tex] takes in a complex valued vector and outputs another complex valued vector... each component of the input is fed into the respective component of [tex]\psi[/tex].
The "input" is real-valued, and the "output" is just one complex number. The input represents a position in space and time. So I shouldn't have said 1-3 variables. It's 4 variables unless we ignore some of the spatial dimensions and/or the time dependence. [itex]\psi:\mathbb{R}^4\rightarrow\mathbb{C}[/itex]
When your book starts talking about spin, you will probably see expressions like [itex]\psi(\vec x)\chi[/itex], where [itex]\psi[/itex] is the same as before and [itex]\chi[/itex] is a [itex]n\times 1[/itex] matrix (n, the number of rows, depends on the spin of the particle).
If I may add something, trying to de-confuse :smile: the OP.
In quantum mechanics, the state of a system (be it a particle, a molecule, or anything else we want to handle with quantum mechanics) is described by, well, a quantum state. For single particles, that quantum state corresponds to "a wavefunction", that is, a complex-valued function over space: psi(x,y,z). Historically, Schroedinger thought it was going to be something similar to the electric potential, V(x,y,z): a kind of field in space. But later, people realized that what was important, was the fact that in the set of quantum states, the superposition principle holds: if A is a state, and B is a state, then a A + b B must also be a state. Turns out that that works pretty well for "wavefunctions": if psi1(x,y,z) is a quantum state, and psi2(x,y,z) is a quantum state, then psi3(x,y,z) = a psi1(x,y,z) + b psi2(x,y,z) is also a quantum state, a wavefunction. But it will turn out that quantum states are not always just "functions over x,y and z" ; it is just in the single particle case that this is so. What is important, is that superposition principle holds, which means that any quantum system must have a set of quantum states which forms a vector space.
It is from that realization that we call the set of quantum states, the "state space" and a quantum state also a "state vector". In the case of a single particle, the state vector is nothing else but a wavefunction of the form psi(x,y,z).
The more "sophisticated" quantum mechanics one does, the less one thinks of "wave functions", and the more one thinks of "vectors in a vectorspace".
Note that the vector space of wavefunctions psi(x,y,z) is infinite-dimensional.
In fact, the vector space of quantum states will turn out to have some other mathematical properties (apart from just being a vector space), and mathematically, a set obeying these properties is called a Hilbert space.
Wouldn't it be fair to add that for [itex]N[/itex] particle systems, we have a wave function of the form
[tex]\psi:\mathbb{R}^{3N+1}\rightarrow\mathbb{C}[/tex]​
with one triple of coordinates for every particle and a time coordinate (usually) added? Correct me if I am wrong.
Harald.
Yes, that's correct for N scalar point particles in an Euclidean space.
But one can think of many other quantum systems, such as spin systems, or fields, or strings, or I don't know what.
FAQ: Eigenstates, Eigenblahs, and Eigenpoofs? HELP O.O
What are eigenstates?
An eigenstate is a state of a quantum system that remains unchanged when a specific operator is applied to it. This operator is known as the eigenvalue of the system.
What are eigenblahs?
Eigenblahs is not a scientific term and is most likely used as a slang term for eigenvalues. Eigenvalues are the values that correspond to the eigenstate of a quantum system.
What is the significance of eigenstates and eigenvalues?
Eigenstates and eigenvalues are important in quantum mechanics as they represent the stable states of a system and the possible outcomes of a measurement, respectively. They also play a crucial role in understanding the behavior of particles and their interactions.
How are eigenstates and eigenvalues calculated?
Eigenstates and eigenvalues can be calculated by solving the Schrödinger equation, which is a mathematical equation that describes the evolution of a quantum system over time. The eigenvalues are the solutions to the equation, and the corresponding eigenvectors are the eigenstates.
Can you give an example of an eigenpoof?
As mentioned before, eigenpoof is not a scientific term. It is most likely used as a humorous term for eigenstates and eigenvalues. However, an example of an eigenstate and eigenvalue in quantum mechanics would be the spin of an electron, where the spin up and spin down states have corresponding eigenvalues of +1/2 and -1/2, respectively.
