Jolb
- 419
- 29
Consider a particle moving in one dimension and bound to an attractive Dirac δ-function potential located at the origin. Work in units such that [itex]m=\hbar=1[/itex]. The Hamiltonian is given, in real (x) space, by:
[tex]H=-\frac{1}{2}\frac{d^2}{dx^2}-\delta (x)[/tex]
The (non normalized) wavefunction [itex]\Psi (x)=<x|\Psi >=e^{-a|x|}[/itex] is an eigenstate of this potential.
a) What is the corresponding wavefunction in wavevector space, [itex]\tilde{\Psi}(k) = <k|\Psi>[/itex]? (Recall that [itex]<x|k>=\frac{1}{\sqrt{2\pi}}e^{ikx}[/itex])
b) Transform the Hamiltonian from the real space basis |x> to the wavevector space basis |k>. Observe that the kinetic energy is diagonal in k-space, but the δ-function potential scatters all wavevectors into all wavevectors with equal amplitude.
c) Now show, by direct calculation in wavevector space, that [itex]\tilde{\Psi}(k)[/itex] is an eigenstate of the Hamiltonian that you found in part (b). You may find the following integral of use: [tex]\int^\infty_{-\infty}\frac{dk}{1+k^2}=\pi[/tex]
a)
[tex]\tilde{\Psi}(k) = <k|\Psi>=\int^\infty_{-\infty}<k|x><x|\Psi>dx=\int^\infty_{-\infty}\frac{1}{\sqrt{2\pi}}e^{-ikx}e^{-a|x|}dx[/tex]
[tex]={Re}\left [2\int^\infty_{0}\frac{1}{\sqrt{2\pi}}e^{-ikx}e^{-ax}dx \right ]={Re}\left [\sqrt{\frac{2}{\pi}}\int^\infty_{0}e^{-(ik+a)x}dx \right ]={Re}\left [\sqrt{\frac{2}{\pi}}\left (\frac{1}{a+ik} \right ) \right ]=\sqrt{\frac{2}{\pi}}\frac{a}{a^2+k^2}[/tex]
All this looks alright to me.
b) Since we're working with units where [itex]\hbar=m=1[/itex], then [itex]\hat{p}=\hat{k}=-i\frac{d}{dx}[/itex]. So the derivative terms just substitute easily with k. All we need now is to Fourier transform the δ potential:
[tex]\tilde{\delta}(k)=\int^\infty_{-\infty}\frac{1}{\sqrt{2\pi}}e^{-ikx}\delta(x)dx = \frac{1}{\sqrt{2\pi}}[/tex]
[tex]\implies\hat{H}=\frac{1}{2}k^2-\frac{1}{\sqrt{2\pi}}[/tex]
This looks okay: term on the left is "diagonal", whereas the term on the right scatters all wavenumbers to another wavenumber without a change in amplitude.
c) This is where I'm realizing something is really screwed up. Obviously we have just changed bases so the wavefunction is still an eigenstate of the potential. But I'm not getting that.
[tex]\hat{H}\tilde{\Psi}(k) = \left ( \frac{1}{2}k^2-\frac{1}{\sqrt{2\pi}} \right )\left (\sqrt{\frac{2}{\pi}}\frac{a}{a^2+k^2} \right )[/tex]
But this looks clearly linearly independent from [itex]\tilde{\Psi}(k)[/itex].
Where have I gone wrong? I didn't use the integral they give you, and I bet I need to use it somewhere to get the right answer. But where?
