Eigenvalues for a non self adjoint operator
In summary, fresh_42 is trying to obtain eigenvalues for an equation that has a very simple second order linear differential operator L acting on function y - so it looks like: L[y(n)] = Lambda (n) * y(n)Where y(n) can be written as a sum of terms in powers of x up to x^n. However, fresh_42 is unsure if it is necessary first to use a weight function w (to convert L to self adjoint form) and if so at what stage. Initial thought was that the eigenvalues are as given by this calculation but that the eigenfunction expansion would have to be calculated as above and then divided it
qtm912
38
TL;DR Summary
Trying to obtain eigenvalues for a non self adjoint linear second order differential operator , but unsure about how (if) to use the weight function
Hi all- I am trying to obtain eigenvalues for an equation that has a very simple second order linear differential operator L acting on function y - so it looks like :
but I find L is non self adjoint. As indicated the question involves assuming that the form of y is a polynomial say in x and use "the equating of coefficients of equal powers method" to work out the coefficients of the x powers and the nth eigenvalue for the expansion. That should be manageable but unsure if it is necessary first to use a weight function w (to convert L to self adjoint form) and if so at what stage. Initial thought was that the eigenvalues are as given by this calculation but that the eigenfunction expansion would have to be calculated as above and then dividing it by the weight function - not sure really if any of this is on the right track.
Guidance appreciated.
Do what you said: write ##y(n)## as polynomial, apply ##L## and compare the terms. No weight functions or self adjoint needed. The equation ##Ly=\lambda y## is the same for any linear function ##L##.
Thanks fresh_42 - thinking about it some more it lines up with what I had in mind - for the eigenvalues anyway. But we have not applied any weight function; now the operator by assumption was not self adjoint so does this not mean that the polynomial terms I later derive in the y expansion that is expressed as a sum of polynomial eigenfunctions in x, will no longer be orthogonal. To make them orthogonal the weight function would play a role would it? If not how would one proceed to obtain an expansion of polynomials in terms of an orthogonal basis.
Noted - and after thinking about it further I realized that orthogonalisation in this case was not necessary using this method of deriving the coefficients. Your comments were very helpful in clearing some doubts thanks - the topic has been fully addressed and can be closed..
Related to Eigenvalues for a non self adjoint operator
1. What are eigenvalues for a non self adjoint operator?
Eigenvalues for a non self adjoint operator are the values that satisfy the characteristic equation of the operator, where the operator is not equal to its adjoint. They represent the possible values that a vector can be scaled by when it is operated on by the non self adjoint operator.
2. How do eigenvalues for a non self adjoint operator differ from those of a self adjoint operator?
Eigenvalues for a non self adjoint operator can be complex numbers, while eigenvalues for a self adjoint operator are always real numbers. Additionally, the eigenvectors for a non self adjoint operator may not be orthogonal, unlike those for a self adjoint operator.
3. Can a non self adjoint operator have real eigenvalues?
Yes, a non self adjoint operator can have real eigenvalues. This occurs when the operator is Hermitian, meaning it is equal to its adjoint. In this case, the eigenvalues are real and the eigenvectors are orthogonal.
4. How are eigenvalues for a non self adjoint operator calculated?
The eigenvalues for a non self adjoint operator can be calculated using various methods, such as the power iteration method or the QR algorithm. These methods involve repeatedly applying the operator to a vector until it converges to an eigenvector, which corresponds to an eigenvalue.
5. What is the significance of eigenvalues for a non self adjoint operator?
Eigenvalues for a non self adjoint operator have many applications in mathematics, physics, and engineering. They can be used to solve differential equations, analyze stability of systems, and understand the behavior of quantum mechanical systems. They also have practical applications in fields such as signal processing and data analysis.
  • Differential Equations
  • Quantum Physics
