Eigenvalues of disturbed Hamiltonian
In summary, the discussion revolves around finding the eigenvalues for a new Hamiltonian H, given a parameter λ, mass m, and original eigenvalues E_n^(0) for the original Hamiltonian H_0. The new eigenvalues are found to be E_n = E_0^(0) - λ^2/2m, while the eigenfunctions have an additional factor due to the shift in momentum by a constant λ.
AwesomeTrains
116
Hello everyone!
I'm trying to follow a solution to a problem from the book "Problems and Solutions on Quantum Mechanics", it's problem 1017. There's a step where they go on too fast, and I can't follow. I've posted the solution and where my problem is down below.
The dynamics of a particle moving one-dimensionally in a potential [itex]V(x)[/itex] is governed by the Hamiltonian [itex]H_0=p^2/2m+V(x)[/itex], where [itex]p=-i\hbar d/dx[/itex] is the momentum operator. Let [itex]E_n^{(0)}, n=1,2,3,...,[/itex] be the eigenvalues of [itex]H_0[/itex]. Now consider a new Hamiltonian [itex]H=H_0+\lambda p/m[/itex], where [itex]\lambda[/itex] is a given parameter. Given [itex]\lambda, m [/itex] and [itex]E_n^{(0)}[/itex], find the eigenvalues of [itex]H[/itex].
The new Hamiltonian is
[itex]H=H_0+\lambda p/m=p^2/2m+\lambda p/m+V(x)=(p+\lambda)^2/2m+V(x)-\lambda^2/2m, [/itex]
or
[itex]H'=p'^2/2m+V(x),[/itex]
where [itex]H'=H+\lambda^2/2m, p'=p+\lambda[/itex]
The eigenfunctions and eigenvalues of [itex]H'[/itex] are respectively [itex]E_n^{(0)}[/itex] and [itex]\psi_n^{(0)}[/itex]
Why does [itex]H'[/itex] have the same eigenfunctions and eigenvalues as [itex]H_0[/itex]?As the wave number is [itex]k'=p'/\hbar=\frac{1}{\hbar}(p+\lambda)[/itex], the new eigenfunctions are
[itex]\psi=\psi^{(0)}e^{-i\lambda x/\hbar}[/itex]
and the corresponding eigenvalues are
[itex]E_n=E_0^{(0)}-\lambda^2/2m[/itex]
Kind regards
Alex
Shifting p by a constant λ does not change the eigenvalues. You just get eigenfunctions with an additional factor (the exponent you have there) compared to the original ones.
Related to Eigenvalues of disturbed Hamiltonian
1. What are eigenvalues in the context of a disturbed Hamiltonian?
Eigenvalues in the context of a disturbed Hamiltonian refer to the possible energy levels of a system that is experiencing some external perturbation or disturbance. They are essentially the solutions to the time-independent Schrödinger equation for the disturbed Hamiltonian system.
2. How are eigenvalues affected by disturbances in a Hamiltonian system?
Disturbances in a Hamiltonian system can change the eigenvalues, leading to a shift in the energy levels of the system. This is because the external perturbation alters the potential energy landscape and can introduce additional terms in the Hamiltonian, resulting in different solutions to the Schrödinger equation and hence different eigenvalues.
3. Can eigenvalues of a disturbed Hamiltonian be calculated analytically?
In most cases, it is not possible to calculate the eigenvalues of a disturbed Hamiltonian analytically. This is because the time-independent Schrödinger equation for a disturbed Hamiltonian often does not have exact solutions and requires numerical methods to solve. However, in some special cases, such as when the disturbance is small, analytical solutions may be possible.
4. How do eigenvalues relate to the stability of a disturbed Hamiltonian system?
The eigenvalues of a disturbed Hamiltonian system can provide information about the stability of the system. If the eigenvalues are real and positive, the system is considered unstable, while negative eigenvalues indicate a stable system. Complex eigenvalues can indicate oscillatory behavior. Additionally, the number and arrangement of eigenvalues can provide insight into the types of motion and stability of the system.
5. Can eigenvalues of a disturbed Hamiltonian be experimentally measured?
Yes, eigenvalues of a disturbed Hamiltonian can be experimentally measured through spectroscopy techniques. By studying the energy levels of a system under different perturbations, the corresponding eigenvalues can be determined. This can provide valuable information about the properties and behavior of the system.
