Eigenvaules and quantum numbers
In summary, the eigenvalues and quantum numbers of a system are related to the observables the system describes. The eigenvalues are the energy levels of the system, while the quantum numbers are the labels given to the energy levels. There is a degeneracy of the energy levels for a conserved observable, which is why there are multiple spectral values for that observable.
khemist
248
Eigenvalues and quantum numbers
My professor was discussing the Schrodinger equation in 3-d today and mentioned that there are degeneracies within quantum numbers (for the hydrogen atom, the x, y, and z components are symmetric?). Does that imply that the eigenvalues of some operator are the quantum numbers of a system? If so, which operator is it?
Studying the Hamiltonian H you see that it is rotationally invariant, i.e. it commutes with all components of orbital angular momentum Li acting as generators of rotations:
[H,Li] = 0
H contains an angular momentum term, namely ~L²/r² which is the familiar additional term in the effective potential (already present in the Kepler problem).
Studying L² and Lz you get eigenfunctions, the so called spherical harmonics Ylm; they are labels by two quantum numbers l and m:
L² Ylm = l(l+1) Ylm
Lz Ylm = m Ylm
The radial part of H is responsible for the quantum number n, so in total the states are labelled as |nlm> with n=1,2,..., l=0,1,...,n-1, m=-l, ...,l-1, l
It's interesting (and I have to admit that I do not understand if there is some deeper reason!) that
a) the radial equation results in a radial wave funtion Rnl(r) where l is due to the additional term in the effective potential ~L²/r² ~ l(l+1)/r², but
b) the eigenvalues Enl do in the very end not depend on l, i.e. are labelled as En ~ 1/n²
So in total you have
H |nlm> = En |nlm>
L² |nlm> = l(l+1) |nlm>
Lz |nlm> = m |nlm>
What are the so-called <quantum numbers> ? Eigenvalues of operators describing observables. So what are these observables which could have a countable number of spectral values ? Energy for once, then spin, then orbital angular momentum, then total angular momentum, then electric charge, then barionic charge, parity, etc.
So for a conserved observable, (its operator, assumed time-independent in the Schrödinger picture) there's always a degeneracy of the discrete energy levels, since each closed subspace associated with an energy value is reduced by the symmetry generator, for example L2 for the spherically-symmetric potentials (free particle in 3D, isotropic oscillator in 3D, H-atom/hydrogenoid ions).
There's an additional conserved quantity in the Kepler problem -the Laplace–Runge–Lenz vector- which is due to a subtle SO(4) symmetry of the potential. This leads to the l-degeneracy of the hydrogen atom energies.
This was my conjecture, but I wasn't sure about it.
That means that for V(r)~1/r with its SO(4) symmetry in dim=3 and for V(r)~r² with its SU(N) symmetry in dim=N we have l-degeneracy, but for no other V(r)~rz (for different z-values). For the harmonic oscillator in dim=N it's trivial to prove SU(N) symmetry and degeneracy, for the hydrogen atom it's more involved.
This was much more in depth than I intended. Thanks for the info. When does this sort of material get introduced in a physics major?
Depends on the curriculum the teacher has prepared for his QM class. You may also get a separate group theory course where applications of group theory to quantum mechanics are presented.
I didn't hear about this in lectures but stumbled upon it by studying symmetry operators for an oral exam. I think that most lecturers don't want to spend half the QM course on the hydrogen atom. ;-)
Correct. This is also responsible for the fact that the Schrodinger equation is separable in two coordinate systems for those two potentials: spherical coordinates, and rectangulars for the harmonic oscillator and parabolic for the Coulomb potential.
FAQ: Eigenvaules and quantum numbers
What are eigenvalues and quantum numbers?
Eigenvalues and quantum numbers are two concepts used in physics and mathematics to describe the properties and behavior of a physical system. Eigenvalues are the possible values that a physical quantity can take on, while quantum numbers are parameters that describe the energy, momentum, and other properties of a system in terms of these eigenvalues.
How are eigenvalues and quantum numbers related?
Eigenvalues and quantum numbers are closely related, as the eigenvalues of a system are often represented by quantum numbers. For example, in quantum mechanics, the energy levels of an atom are described by the quantum number n, which corresponds to the eigenvalue of the energy operator.
3. What is the significance of eigenvalues and quantum numbers?
Eigenvalues and quantum numbers are important in understanding the behavior of physical systems and predicting the outcomes of experiments. They provide a mathematical framework for describing how particles and energy interact and how systems evolve over time.
4. How are eigenvalues and quantum numbers calculated?
Eigenvalues and quantum numbers can be calculated using mathematical equations and formulas that take into account the properties of the physical system being studied. These calculations are often complex and require advanced mathematical techniques, such as linear algebra and quantum mechanics.
5. What are some examples of systems that use eigenvalues and quantum numbers?
Eigenvalues and quantum numbers are used to describe a wide range of physical systems, including atoms, molecules, nuclei, and subatomic particles. They are also used in various branches of physics and engineering, such as quantum mechanics, electromagnetism, and signal processing.
