Eigenvectors - eigenvalues mappings in QM
In summary, in non-relativistic QM, for a given observable M and wave function Ψ, each unique eigenvalue of M has at least one corresponding eigenvector. However, there can be multiple eigenvectors within a subspace for one eigenvalue. On the other hand, if a set of distinct eigenvectors is given, each has only one unique eigenvalue. It is never the case that one eigenvector has multiple eigenvalues. This can be verified in the wikipedia article on eigenvalues and eigenvectors, where it is explained that a linear transformation on a vector must result in a unique outcome. This is demonstrated by the equation (lambda - mu) * x = 0, where either x =
LarryS
33
In non-relativistic QM, say we are given some observable M and some wave function Ψ. For each unique eigenvalue of M there is at least one corresponding eigenvector. Actually, there can be a multiple (subspace) eigenvectors corresponding to the one eigenvalue.
But if we are given a set of distinct eigenvectors to start with, then there is always just one unique eigenvalue for each of those distinct eigenvectors. There are never multiple eigenvalues associated with just one eigenvector. Is that a true statement?
Yes, see the wikipedia article on eigenvalues and eigenvectors. If you apply a linear transformation to a vector, you need to get a unique result. For example, if you apply a reflection across a given line to a vector, you don't get two reflections.
Likes bhobba
Formally, we get for an eigenvector ##x## of ##\psi## with two eigenvalues ##\lambda , \mu## the equation ##\psi.x=\lambda \cdot x = \mu \cdot x## and so ##(\lambda - \mu)\cdot x = 0##. So we have either the zero vector ##x=0##, which is contained in all eigenspaces, or identical eigenvalues ##\lambda = \mu\,##.
Likes bhobba and dextercioby
FAQ: Eigenvectors - eigenvalues mappings in QM
1. What are eigenvectors and eigenvalues in quantum mechanics?
Eigenvectors and eigenvalues are mathematical concepts used in quantum mechanics to describe the state of a quantum system. An eigenvector is a vector that remains unchanged when multiplied by a particular matrix, known as the operator. In quantum mechanics, the eigenvector represents the state of the system, and the corresponding eigenvalue represents the result of a measurement of that state.
2. How are eigenvectors and eigenvalues used in quantum mechanics?
Eigenvectors and eigenvalues are used to describe the possible states of a quantum system and the outcomes of measurements on those states. They are also used to calculate the evolution of a quantum system over time, as the eigenvectors and eigenvalues of the Hamiltonian operator (which describes the total energy of the system) determine the possible energy levels and transitions in the system.
3. What is the significance of eigenvectors and eigenvalues in quantum mechanics?
The concept of eigenvectors and eigenvalues is crucial in quantum mechanics because it allows us to describe and understand the behavior of quantum systems. By determining the eigenvalues and eigenvectors of an operator, we can calculate the probabilities of different outcomes of measurements and predict the evolution of the system over time.
4. Can an operator have multiple eigenvectors and eigenvalues?
Yes, an operator can have multiple eigenvectors and eigenvalues. Each eigenvector corresponds to a different eigenvalue, and the number of eigenvectors is equal to the dimension of the vector space. In quantum mechanics, operators can have multiple eigenvectors and eigenvalues, representing the different possible states and measurements of a quantum system.
5. How are eigenvectors and eigenvalues related to each other?
Eigenvectors and eigenvalues are closely related in that the eigenvectors determine the eigenvalues and vice versa. An eigenvalue represents the result of a measurement on the corresponding eigenvector, and the eigenvector represents the state of the system associated with that eigenvalue. In quantum mechanics, the eigenvectors and eigenvalues of an operator are used to determine the possible states and outcomes of measurements in a quantum system.
