A Eigenvectors of the Permittivity Tensor in Periodic Dielectrics
The discussion focuses on the relationship between the eigenvectors of the effective permittivity tensor in periodic dielectrics and the principal axes of crystal symmetry. The original poster seeks a formal proof that these eigenvectors align with the crystal symmetry, noting consistency with their simulations. A response suggests that this alignment may not always hold true, particularly in cases involving strained crystal lattices or chiral phases. The original poster later references Neumann's principle, which implies that the symmetry of physical properties must reflect the crystal's point group symmetry, but acknowledges potential limitations to materials described by symmetric tensors. The conversation highlights the complexity of this relationship in various material contexts.
sph711
TL;DR Summary
Looking for a derivation or proof that the eigenvectors of the effective permittivity tensor of a periodic dielectric structure align with the principal axis of the crystal symmetry of said periodic strucutre.
Hi all,
(first post here :D)
I am working on periodic dielectric structures in the long-wavelength limit (wavelength much larger than the periodicity). In the long wavelength limit the periodic strucutre can be homogonized and described via an effective permittivity (or refractive index) tensor.
I think it would make sense that the eigenvectors of said homogenized permittivity tensor would correspond to the principal axis of the crystal symmetry of the periodic structures. This also corresponds well with what I am seeing in my simulations. However, I cannot think of a way to show this formally.
Could anybody point me to an existing proof or guide me in how to approach the problem mathematically?
sph711 said:
TL;DR Summary: Looking for a derivation or proof that the eigenvectors of the effective permittivity tensor of a periodic dielectric structure align with the principal axis of the crystal symmetry of said periodic strucutre.
Interesting question!
I'm not sure this is always true, I'm thinking about acousto-optic devices (with strained crystal lattices), and also chiral phases (especially liquid crystals). I can't find a reference either though, perhaps this one will give you some ideas:
https://opg.optica.org/directpdfacc...-17-6-4442.pdf?da=1&id=177143&seq=0&mobile=no
Thank you for your reply. However, the link you provide did not work for me
I did some more research today, and I think I found what I was looking for. I came across the Neumanns principle which states "The symmetry of any physical property of a crystal must include the symmetry elements of the point group of the crystal." (properties of materials, Robert E Newnham - page 35 -
[Link to PDF of copyrighted textbook deleted by the Mentors]
If I understand it correctly this should mean that yes, the principle axis of the crystal are the same as the Eigenvectors of material properties, there is also an analytical form of this principle in the link above. But I did not have time yet to go through it.
However, I think you are right, this should not always be the case. I might be wrong, but I think it is limited to mateirals that can be described with a symmetric tensor. Will update as soon as I am sure.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
