Einstein manifolds as asymptotic background spacetimes in Type IIB string theory
In summary, the AdS/CFT correspondence can be extended and generalized in various ways, including considering different dimensions and deforming both sides of the correspondence. The spaces ##AdS_{5}\times S^{5}## and ##S^{5}## are both considered Einstein manifolds, which are necessary for defining a Type IIB string theory in the context of the correspondence.
Afonso Campos
29
On page 30 of the notes (https://arxiv.org/abs/1501.00007) by Veronika Hubeny on The AdS/CFT correspondence, we find the following:
So far, we have been describing just one particular case of the AdS/CFT duality, namely (3.3). There are however many ways in which the correspondence can be extended and generalized. The earliest and most immediate one was to consider different number of dimensions, i.e. to describe a dual of a gravitational theory on ##AdS_{d+1}## (times a compact manifold) in terms of a ##d##-dimensional CFT, on which we elaborate below. Another straightforward type of generalization constitutes starting with (3.3) and deforming both sides in a controlled way. If we add extra terms to the Lagrangian, the gauge theory is no longer conformal; it will undergo renormalization group flow (which gives an effective description at a given energy by integrating out the higher-energy degrees of freedom). This is directly mimicked by the behavior of the bulk geometry in the radial direction. Depending on the type of deformation, we can get quite a rich set of possibilities, including ones where the low-energy physics is confining, massive, chiral symmetry breaking, etc. One can also replace the ##S^5## by any other Einstein manifold or a quotient of the ##S^5##, which gives rise to more complicated gauge theories. More interestingly, one can even consider different asymptotics.
Are ##AdS_{5}\times S^{5}## and ##S^{5}## Einstein manifolds?
Do only Einstein manifolds and quotients of Einstein manifolds qualify as the asymptotic background spacetimes on which you can define a Type IIB string theory?
Hello,
Thank you for bringing up this interesting topic on the AdS/CFT correspondence. To answer your first question, yes, both ##AdS_{5}\times S^{5}## and ##S^{5}## are considered Einstein manifolds. An Einstein manifold is defined as a Riemannian manifold with constant scalar curvature, and both of these spaces have this property. In fact, the ##S^{5}## is a maximally symmetric space with positive scalar curvature, while ##AdS_{5}\times S^{5}## has negative scalar curvature.
To address your second question, it is true that only Einstein manifolds and their quotients are considered as suitable asymptotic backgrounds for defining a Type IIB string theory. This is because the AdS/CFT correspondence relies on the fact that the spacetime on which the gravitational theory is defined (in this case, ##AdS_{d+1}##) has a conformal boundary. This boundary is necessary for the dual CFT to exist and for the correspondence to hold. Einstein manifolds and their quotients are the only known spacetimes that have this property, making them the most suitable for defining a Type IIB string theory.
I hope this helps clarify any confusion. If you have any further questions, please feel free to ask.
Related to Einstein manifolds as asymptotic background spacetimes in Type IIB string theory
1. What are Einstein manifolds?
Einstein manifolds are Riemannian manifolds, which are mathematical spaces that locally resemble Euclidean space, and have the property that their metric tensor satisfies the Einstein field equations. These equations are a set of equations in general relativity that describe the curvature of spacetime in the presence of matter and energy.
2. How are Einstein manifolds related to Type IIB string theory?
In Type IIB string theory, the spacetime is described by a 10-dimensional manifold. This manifold can be decomposed into a product of two 5-dimensional manifolds, one of which is an Einstein manifold. This Einstein manifold is known as the "asymptotic background spacetime" and plays a crucial role in the dynamics of Type IIB string theory.
3. What is the significance of asymptotic background spacetimes in Type IIB string theory?
The asymptotic background spacetime in Type IIB string theory is important because it serves as a reference point for the dynamics of the theory. It is the background against which string interactions and particle scattering are measured.
4. Are Einstein manifolds the only type of asymptotic background spacetimes in Type IIB string theory?
No, there are other types of asymptotic background spacetimes in Type IIB string theory, such as Anti-de Sitter (AdS) spacetimes. AdS spacetimes are also Einstein manifolds, but they have negative curvature, whereas the asymptotic background spacetimes have zero curvature.
5. How do Einstein manifolds as asymptotic background spacetimes affect the behavior of strings in Type IIB string theory?
The presence of an Einstein manifold as an asymptotic background spacetime in Type IIB string theory affects the behavior of strings by influencing the way in which they interact and scatter. The curvature and geometry of the Einstein manifold can alter the paths of strings and modify their scattering amplitudes.
  • Beyond the Standard Models
17K
