Einstein relativity between 2 coordinates systems
The discussion revolves around calculating the speed of a moving coordinate system using the Lorentz transformation. The user initially calculated a speed of V' = 1.2 m/s but needs to find a solution of -1.2 m/s. It is clarified that the standard transformation is from the unprimed frame to the primed frame, but the user should apply the inverse transformation since the data provided is in the primed frame. This adjustment is essential to accurately determine the speed at which the two events occur at the same point in the unprimed frame. Understanding the correct application of the Lorentz transformation is crucial for solving the problem.
Atabold
Two coordinate events (24 s, 12 m) and (35 s, 25 m) occur on the x' axis of the system S'. At what speed must S' translate in order for the two events occur at the same point for S?
What is the x coordinate of this point?
V' = ( x'f — x'i ) / ( t'f — t'i )
I calculated the speed using the information provided through the above equation and finding V' = 1.2 m/s.
However, the first solution must be -1,2 m/s. I don't know how to reach it, any suggestion?
Atabold said:
Homework Statement: Two coordinate events (24 s, 12 m) and (35 s, 25 m) occur on the x' axis of the system S'. At what speed must S' translate in order for the two events occur at the same point for S?
Relevant Equations: V' = ( x'f — x'i ) / ( t'f — t'i )
Are you doing the standard, conventional transformation or the inverse? Which should it be?
I have done the Lorentz transformation
The usual convention for the LT is to transform from the unprimed frame to the primed frame. You need the inverse transformation here, as you have data in the primed frame.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
