Einstein summation convention in QM
In summary: However, in the relativistic QM with Dirac equation summation is needed.In summary, in the non-relativistic QM convention is not always followed, but in relativistic QM with Dirac equation summation is needed.Thanks
dyn
773
62
Hi
For an operator A we have Aψn = anψn ; the matrix elements of the operator A are given by Amn= anδmn
My question is : is this an abuse of Einstein summation convention or is that convention not used in QM ?
Thanks
The Einstein convention is not a universal standard.
In general, linear algebra textbooks have not been rewritten to conform to the Einstein summation convention.
Likes vanhees71, ohwilleke, topsquark and 1 other person
Thanks
The equation i wrote was from a modern QM textbook so it seems that i can assume the convention is not always followed in QM
Authors tend to clearly state when they are (and when they are not) using Einstein convention, generally speaking.
Likes vanhees71, ohwilleke and topsquark
If you wanted to keep the summation convention in this example, then ##a_n## would be better written as ##a(n)##, a function depending on a discrete variable ranging over the dimension of the underlying Hilbert space.
dyn said:
Hi
Thanks
Is there a way to write this equation using Einstein convention or are some equations impossible to write using that convention ?
dyn said:
Hi
Thanks
This equation does not involve a sum, so why should a summation convention be used?
In more detail: it looks like ##A## is a selfadjoint operator, and that ##\left\{ \left| \psi_i \right> \right\}## is a complete set of eigenstates of ##A##. Then,
$$A_{mn} = \left< \psi_m |A| \psi_n \right> = a_n\left< \psi_m | \psi_n \right> = a_n \delta_{mn} .$$
No sums or summation convention anywhere.
Likes malawi_glenn, topsquark, Vanadium 50 and 4 others
The part of QM where the summation convention is actually needed, is the relativistic QM with Dirac equation. There you have 4-vectors with matrix-valued coefficients, and only the 4-vector components are handled with this convention, not the spinor components.
Likes dyn, topsquark and vanhees71
If the summation convention was followed on the RHS then the index n would be summed over because it appears twice leaving the index m which should be the only index appearing on the LHS. As far as i am aware that it how it works in SR with the summation convention
Likes topsquark and vanhees71
But the equation in your original post does not involve a sum!
Likes topsquark
If an index appears twice in a term does that not imply summation ?
No. In non-relativistic QM implicit summations are never employed.
Likes Vanadium 50, vanhees71, topsquark and 1 other person
If you look back to post #7, the sum has already been taken. The Kronecker delta picks out the n term of the expansion and we get ##a_n \mid \psi _n >##. The two indicies just happen to have the same value after the summation.
-Dan
Likes vanhees71
No. You're going to run into problems if you assume the Einstein summation is the universal default in mathematics and physics.
I don't know where you've got that idea from.
Likes DrClaude, Vanadium 50, dyn and 2 others
I'd also not recommend to introduce the Einstein summation convention in QT in this way, because you quite often need formulae as discussed here. I think, it's useful in the manipulation of tensor components in the Ricci calculus and should be used only for this purpose, and that's indeed where it is used in the literature.
Likes dyn, topsquark and PeroK
Not always
Likes vanhees71, Vanadium 50 and topsquark
dyn said:
Hi
Thanks
The QM Fields book I have by Schwartz says they don't bother with upstairs and downstairs indexes and anything with the same letter is summed over.
But this equation would create a contradiction: ## A \psi _n = a_n \psi _n##. If the n's were summed on the RHS then the n's go away. Why is there still an n on the LHS? It would make no sense. Clearly there must be exceptions. Any operation with a trace involved would cause this problem.
-Dan
As I said, it would be very inconvenient to introduce the summation convention in cases, where it makes things more complicated. In QM I'd not introduce it at all. Of course, if you deal with tensor operators, including field operators in QFT, I'd use them for the indices for these objects but not for bras and kets.
Likes DrClaude and topsquark
-Dan
Yeah, maybe I misspoke. Let me look up the exact wording.
FAQ: Einstein summation convention in QM
What is the Einstein summation convention in QM?
The Einstein summation convention is a shorthand notation used in quantum mechanics to simplify the writing of equations involving repeated indices. It states that whenever an index appears twice in a single term, it is implicitly summed over all possible values.
Why is the Einstein summation convention used in QM?
The Einstein summation convention is used in QM to simplify the writing of equations and make them easier to read and understand. It also helps to reduce the number of terms in an equation, making it more concise.
How does the Einstein summation convention work?
The Einstein summation convention works by replacing repeated indices with a summation symbol, which indicates that the index is being summed over all possible values. This allows for a more compact and efficient representation of equations in QM.
What are the benefits of using the Einstein summation convention in QM?
Using the Einstein summation convention in QM can save time and effort in writing and understanding equations. It also helps to avoid errors that may arise from writing out all the terms explicitly. Additionally, it allows for a more elegant and concise representation of equations.
Are there any limitations to the Einstein summation convention in QM?
One limitation of the Einstein summation convention in QM is that it only applies to repeated indices within a single term. It cannot be used for more complex equations involving multiple terms or indices. Additionally, it may not be suitable for all situations and may not be preferred by all scientists.
