cianfa72
- 2,205
- 241
Consider an "unidimensional elevator" of size L accelerating w.r.t. a given inertial reference frame. Suppose each elevator's point accelerates with a constant proper acceleration ##g## according Rindler acceleration profile. In the given inertial frame with coordinates ##(x,t)## the elevator points's worldlines are described by:
$$x = R\cosh\eta, \qquad t = R\sinh\eta$$
AFAIK based on Equivalence Principle (EP) all experiments executed inside the "unidimensional elevator" can be explained introducing an uniform gravitational field inside it. The Equivalence here is not just local but we can extend it for the entire region of flat spacetime involved.
Now suppose you leave a particle at rest at quote ##R_{0}## in the elevator. At that moment I believe it shares the proper acceleration of the elevator point in which it is at rest and then, during its free-fall, it follows a geodesic described as just a straight line in ##(x,t)## coordinates. Basically its initial proper acceleration has been "converted" into the elevator ##(R,\eta)## coordinate acceleration.
If what said is correct, now each elevator point (with spatial ##R_{x}## coordinate inside the elevator itself) has a different proper acceleration (according Rindler acceleration profile) thus the coordinate acceleration for objects released from rest at different elevator quotas is not a constant; in other words my conclusion is that uniform gravitational field inside the elevator is not the case !
Can you help me in understanding if the argument is right or where is wrong ? Thanks.
