Exploring Einstein's Theory of Gravity: Time Dilation and Tidal Forces
In summary: This is known as gravitational time dilation and is caused by the difference in the gravitational potential rather than the acceleration.
klen
41
I have some questions related to this video:
In the Einstein view of gravity, time is warped. Is this warped time same as the gravitational time dilation? In other words, is the curved time axis due to different clock speeds at different height in a gravitational field?
Further, can the tidal forces be explained in terms of gravitational time dilation?
It would be much more accurate to say that spacetime is curved. One of the effects of curvature is that initially parallel lines may converge of diverge. For example, if I pick two nearby points at the equator and draw lines due north the lines will be parallel at the equator yet will meet at the North pole.
No, for all three questions. Gravitational time dilation and the gravitational field are both caused by the curvature and not the other way around.
Tidal forces can easily be observed even when there is no gravitational time dilation. If I hold two clocks one meter apart and drop them in the Earth's gravitational field, there will be no time dilation - both clocks will read the same when they hit the floor, despite having taken different paths through spacetime - but there will be a tidal force that causes them to move closer to one another as they fall. To get time dilation, I have to send the clocks on paths of different length through spacetime, and that's quite unrelated to whether curvature causes these paths to converge or diverge.
Could you please explain the reason behind this. I see no flaw in saying that gravitational time dilation is time warping. I think the constant speed of light in the inertial frames is the cause of this time dilation which is manifested as a curved time (locally) in a gravitational field.
What is time warping?
Time alone cannot be "warped". You need at least one spatial dimension, with different clock rates along it. This can be interpreted geometrically as a metric of space-time.
In simple terms: Gravitational acceleration is related to the first derivative of gravitational time dilation. Tidal effects are related to the second derivative of gravitational time dilation
Likes Fuinne
The curvature of time axis is what I am calling time warping.
This is true, what I am saying is we can consider this time "warping" or the curvature of the time axis as can be seen in the video to be the gravitational time dilation. In other words, the difference in the clock rates at different heights is what is meant by this curved time line.
How do you define a curvature on only one dimension?
Hi Smattering, as I said earlier, I am not trying to define curvature in one dimension. I am only talking about the curvilinear time coordinate which is used to explain the falling of the object "near" Earth's surface as is shown in the video, so I am neglecting the tidal effect. I understand the space-time in the given situation is flat but we are using a "curved" time coordinate since time flow now depends on height of the object. Thus I wanted to understand if the curvilinear time coordinate due to height dependent time.
I also found a link which gives a really good interpretation of GR:
http://spark.sciencemag.org/generalrelativity/
I think the explanation in the link is in line with what I was trying to say so I think I am right.
As others have pointed out, a 1D line, like the time axis, has no intrinsic curvature. However, it can have extrinsic curvature. The extrinsic curvature of the time axis would represent the proper acceleration measured by an accelerometer at rest wrt the reference frame.
This is not what causes gravitational time dilation. Gravitational time dilation is due to a difference in the gravitational potential, not the gravitational acceleration. For example, a clock inside a hollow sphere will be time dilated despite having an "unwarped" time axis.
As a general suggestion, when learning a new field, it is better to try to learn the standard terminology rather than invent your own.
As I have already said I am not talking about curvature but curvilinear time coordinate:
Also I do not understand what do you mean by time dilation inside a hollow sphere. Since it has no gravitational field, time would flow at same rate at any position inside hollow sphere. So when you are saying dilated, dilated with respect to what?
Did you not read my comments on extrinsic curvature (the correct term for your "curvilinear or warped time) as well as the connection to proper acceleration and accelerometers at rest? I explained the physical meaning of your "curvilinear time coordinate"
It would very much help if you would adopt the standard terminology once it has been pointed out. I am trying to help you learn the language as well as the physics of the concepts you are grasping at.
With respect to a clock outside the sphere
If you are considering dilation w.r.t to clock outside the spherical shell, then I think you are wrong in saying that time does not have extrinsic curvature, now using the correct terminology according to you. This is because as we cross the boundary of the shell we would see the curved (extrinsic) time axis.Clearly, as you said, the dilation only makes sense once we cross the surface of the spherical shell because then only we can say that time inside the shell is dilated. So time is not "unwarped" as you said.
I understand that and I am also trying to learn from you but still not convinced with your arguments.
The fact that you have to know the gravitational acceleration (extrinsic curvature of time axis) between the clocks is directly related to the fact that gravitational time dilation is a function of the gravitational potential.
See page 103 here http://arxiv.org/abs/gr-qc/9712019
I am not interested in arguing or convincing. If you are interested in learning then I am glad to help. Otherwise you can just read the textbook.
I know all this and I in my original question I did not ask for reason as to why clocks in gravity run at different speeds. I was trying to ask about its implications.
This is not true. The difference in gravitational potential between any two points inside hollow sphere is zero, so time is not dilated inside the hollow sphere if we are restricting ourselves inside the hollow sphere.
Hi DaleSpam,
If you are considering w.r.t. clock outside the sphere then there is gravitational potential between any point outside and inside the sphere so time is dilated and is not "unwarped" in this case. Again your original statement time can be dilated despite "unwarped" time axis is wrong.
I never said this. In the original question I was asking about time dilation near the surface of the Earth and I know that acceleration due to gravity is same near the surface of the earth.
A note on terminology:
From mid-1911 to mid-1912, Einstein tried to explain tidal gravity
by assuming that time is warped, but space is flat
(Reference: Black Holes and Time Warps, Einstein's Outrageous Legacy - Kip Thorne, p. 107)
An example is the transition from an inertial reference frame (in which free particles coast along straight paths at constant speeds) to a rotating reference frame (in which extra terms corresponding to fictitious forces have to be introduced in order to explain particle motion): this is analogous to the transition from a Cartesiancoordinate system (in which the coordinate lines are straight lines) to a curved coordinate system (where coordinate lines need not be straight).
(Reference: Wikipedia, https://en.wikipedia.org/wiki/Introduction_to_general_relativity)
in general, rays of light are propagated curvilinearly in gravitational fields
(Reference: Relativity: The Special and General Theory - Albert Einstein, p.65)
These references are standard enough for me to use the terms from them in my question. These terms are not a product of my own neologism. Further, I know the difference between intrinsic and extrinsic curvature and it is totally irrelevant to what I intended to ask in my question.
I am reading books on GR, thank-you for the advise. I would also advise you the same because looking at your answers I think you require to brush up your concepts.
In my opinion, Klen, your phrasing is too imprecise and non-standard. That's what causes the miscommunication. Time is not a natural concept in relativity, except of course for proper time. Thus when you refer to time as if there is one unique such thing it is very unclear what you mean and it seems that you are using classical (non-relativistic) intuition. Forget the popular book, find one modern textbook on general relativity that uses the phrase " time is warped" and then we can see what you actually mean.
klen said:
I know all this
Excellent. Since you already know all this then we can close this thread and help other people who do not have such advanced understanding as you.
Related to Exploring Einstein's Theory of Gravity: Time Dilation and Tidal Forces
1. What is Einstein's theory of general relativity?
Einstein's theory of general relativity is a theory of gravity that explains how massive objects in the universe interact with one another. It states that gravity is not a force between objects, but rather a result of the curvature of space and time caused by the presence of massive objects.
2. How does Einstein's theory of general relativity differ from Newton's theory of gravity?
Unlike Newton's theory, which describes gravity as a force, Einstein's theory of general relativity describes gravity as a curvature of space and time. This theory also incorporates the concept of spacetime, where space and time are interconnected and affected by the presence of matter and energy.
3. What is the significance of Einstein's theory of general relativity?
Einstein's theory of general relativity revolutionized our understanding of gravity and the universe. It has been proven to be accurate in predicting the behavior of massive objects, such as planets and stars, and has led to the discovery of black holes and gravitational waves.
4. How does Einstein's theory of general relativity relate to the concept of time dilation?
According to Einstein's theory of general relativity, time is not constant and can be affected by the presence of massive objects. This means that time can pass at different rates depending on the strength of gravity. This phenomenon is known as time dilation and has been confirmed through experiments and observations.
5. Can Einstein's theory of general relativity be applied to everyday life?
While Einstein's theory of general relativity is most commonly applied to the study of the universe and astronomical objects, it also has practical applications in everyday life. For example, GPS systems use this theory to correct for time dilation effects caused by the Earth's gravity, ensuring accurate location tracking.
