Either my professor made a boo-boo or I don't get it(regarding E=mc^2)
In summary, the conversation discusses the relationship between work and change in kinetic energy, and how it applies in both classical and relativistic mechanics. The participants also discuss how potential energy may or may not be involved in the equation, and the importance of the limit of velocity approaching 0. They also give advice on how to approach the problem mathematically.
schattenjaeger
178
either way, you can help! so w=change in KE, and W=the line integral from 0 to s of FdotdS(I never learned how to use the latex thingy, so bear with me, the question isn't that hard...)
So then he wrote KE=lineintegral from 0-S, d/dt(gamma*mv)ds
and then from there you end up with gamma*mc^2-mc^2 after a whole bunch of math, which you take to mean the total energy - the "rest" energy? So...shouldn't up there you write change in KE=lineintegral etc...? If it IS just KE, I don't know why, since the line integral definition is for work anyways...well that may be a little confusing in just words, sorry
At the time when that he replaced Work with Delta KE,
there didn't seem to be any Potential Energies involved.
And with no "non-conservative" processes, KE_0 = 0.
If you want to interpret mc^2 as a PE, go ahead -
the important thing is the limit v = 0 .
I've never heard mc^2 called
a "KE of the object at speed v=0" .
If you need something to ponder here, how about
whether "non-conservative" is well-defined anymore.
schattenjaeger, first i would suggest looking at some posts with tex in it (press the quote button to look at the syntax, but don't save) to get this math formatting down. and there are also some sticky posts that describe it.
second, forget about vectors and three dimensions for a moment. in fact, forget about relativity for the time being. given a single dimension (the "x" dimension), can you take a force field, with constant force [tex] F [/tex] and known length [tex]l[/tex], let a particle of mass [tex]m_0[/tex] enter this force field at the, say, left side with velocity zero, and then determine what the velocity is when it comes out the right side? do it first for the classical case where the mass is constant [tex] m = m_0 [/tex]:
[tex] F = \frac{dp}{dt} = \frac{d(mv)}{dt} = m_0 \frac{dv}{dt} = m_0 a [/tex]
then do it for the relativistic case:
[tex] F = \frac{dp}{dt} = \frac{d(mv)}{dt} = m \frac{dv}{dt} + v \frac{dm}{dt} [/tex]
where
[tex] m = \frac{m_0}{\sqrt{1 - v^2/c^2}} [/tex]
use all the theorems you learned in calculus to do derivatives. i think then you'll figure it out.
rots o' ruk.
rbj said:
i don't know why, but sometimes the tex rendering of this site really screws up. i'll try it in another new post. hey moderators, how do i completely kill a post of my own (instead of just editing it)?
When you edit your post, there's an option to delete it.
Zz.
thanks, Zz. maybe someday i'll look at these things. (i never read directions either.)
rbj said:
[tex]
where
I'm not sure where this is leading is, or what the question is. Doing what you suggest (with a change back to the original posters notation of m=[itex]m_0[/itex]), I get:
[tex]
p = \frac{m v}{\sqrt{1-\left(\frac{v}{c}\right)^2}}
[/tex]
[tex]
F = \frac{dp}{dt} = \frac{dp}{dv} \, \frac{dv}{dt} = \frac{m }{\left( 1-\left( \frac{v}{c} \right)^2 \right)^{\frac{3}{2}}} \, \frac{dv}{dt}
[/tex]
i think the OP wants to know how to get the relativistic kinetic energy to come out as:
[tex] T = m c^2 - m_0 c^2 = E - E_0 [/tex]
where
(and then you interpret that first term to be the total energy [itex]E[/itex] and the second term to be the rest energy [itex]E_0[/itex].)
in the classical case where the mass is constant [itex]m = m_0[/itex], then you can show that with a force field with constant force [itex]F[/itex] and length [itex]l[/itex], a object of mass [itex]m_0[/itex] enters it at velocity [itex]v_1[/itex] and exits at velocity
[tex] v_2 = \sqrt{\frac{2 F l}{m_0} + v_1^2} [/tex]
or
[tex] \frac{1}{2} m_0 v_2^2 = \frac{1}{2} m_0 v_1^2 + F l [/tex]
which is where we get the concept of kinetic energy from. if the initial velocity is zero, the final velocity depends only on the product of [itex]F[/itex] and [itex]l[/itex] or the work performed on the object and not on the any other function of [itex]F[/itex] and [itex]l[/itex].
[tex] T_2 = T_1 + F l = T_1 + W [/tex]
[itex] T_1 [/itex] and [itex] T_2 [/itex] are the initial and final kinetic energies.
to do that in the classical mechanics case ain't too hard. to do it in the reletivistic case, where the mass is not constant is harder, of course. if no one else picks this up, i'll work on it and if i get it, i'll post it later.
FAQ: Either my professor made a boo-boo or I don't get it(regarding E=mc^2)
What is the meaning of E=mc^2?
E=mc^2 is a famous equation introduced by Albert Einstein in his theory of special relativity. It states that energy (E) is equal to mass (m) multiplied by the speed of light (c) squared.
How is E=mc^2 derived?
E=mc^2 is derived from Einstein's postulates, which state that the laws of physics are the same for all observers in uniform motion and the speed of light is constant for all observers. By combining these postulates with mathematical equations, Einstein was able to derive the famous equation.
Why is E=mc^2 important?
E=mc^2 is important because it revolutionized our understanding of energy and mass. It showed that they are two sides of the same coin and can be converted into each other. This theory also has significant implications in fields such as nuclear energy and astrophysics.
Is E=mc^2 always true?
Yes, E=mc^2 is always true. It is a fundamental law of physics and has been extensively tested and proven to be accurate. However, it may not be applicable in extreme situations such as black holes or the beginning of the universe, where other theories may need to be considered.
How does E=mc^2 relate to nuclear reactions?
In nuclear reactions, a small amount of mass is converted into a large amount of energy according to E=mc^2. This is because the nucleus of an atom contains a huge amount of energy in the form of mass, which can be released through nuclear reactions. This has led to the development of nuclear energy and weapons.
16K
