Ejection of Only one electron by a Photon in the Photoelectric effect
In summary: But that original one photon that entered the material has now kicked out more than one electron. So that in itself has already answered your original question. But now comes the details, because, for example, how would we know that an Auger process took place?This is where one has to look at the details of the emitted electron spectrum. The Auger process has a distinct spectrum where by it actually gives you info about the core level states. A "compton scattering" does not, because the compton spectrum is typically broad!Besides, there's another important issue here. When an energetic electron bumps into another electron, this is a "lossy" process in terms of energy of the original electron. In fact, an
Zahid Iftikhar
121
24
Hi
I am surprised to know why only one photon in photoelectric effect ejects one electron only. What if a high energy photon (not necessarily x-ray or gamma ray, which may cause Compton effect or pair production)hits the metal, say it has energy double or triple of that of the work function? Why does not it eject two or more electrons?
Please help.
Regards
That process is possible but very unlikely. In general reactions get less likely the more particles have to be involved.
Please some more information.
Regards
Zahid Iftikhar said:
Hi
Please help.
Regards
First of all, an energetic photon may cause more than one electron to be ejected, but NOT via the photoelectric effect. The Auger process can certainly result in more than one electron being ejected per photon.
But for the photoelectric (or more accurately, a photoemission) process, the entire energy of the photon is absorbed on one shot. There is no partial absorption. This is, by definition, the photoemission process. If the process involves anything else, then it is called something else.
Zz.
Likes Wrichik Basu
Zz.
Thanks indeed for your kind reply. To my understanding Auger process involves ionization of an atom due to emission of inner electron after being hit by high energy photon. The vacancy thus created is filled by some electron from higher orbits. Another photon thus created hits another electron and kicks it out. In all this chain, still one photon knocks out one electron. This is what I want to know. Even in Compton effect, we see same thing happens. Please spare some more time for my query.
High regards.
High regards.
Besides, there's another important issue here. When an energetic electron bumps into another electron, this is a "lossy" process in terms of energy of the original electron. In fact, an electron that already has enough energy to escape a material will tend to lose that energy quite easily if it bumps into another electron before it escapes the material. This is why metals are usually poorer photocathodes than semiconductors, because metals have more free electrons than semiconductors. So a "compton process" inside a solid is often detrimental to the emission of electrons from that solid.
Zz.
Likes dlgoff
Related to Ejection of Only one electron by a Photon in the Photoelectric effect
1. What is the Photoelectric effect?
The Photoelectric effect is a phenomenon in which electrons are ejected from a material when it is exposed to light of a certain frequency. This was first observed by Heinrich Hertz in 1887, and was later explained by Albert Einstein in 1905 through his theory of the quantization of light.
2. How does a photon eject only one electron in the Photoelectric effect?
When a photon of the correct frequency strikes a material, it transfers its energy to an electron within the material. This energy is enough to overcome the binding energy of the electron, causing it to be ejected from the material. However, the energy of the photon must be greater than the binding energy of the electron, otherwise no electron will be ejected. This is why only one electron is ejected by a single photon in the Photoelectric effect.
3. What factors determine the energy of the ejected electron in the Photoelectric effect?
The energy of the ejected electron depends on the frequency of the incident photon and the binding energy of the electron in the material. The higher the frequency of the incident photon, the greater the energy transferred to the electron and the higher its kinetic energy upon ejection. The binding energy of the electron is determined by the type of material and the energy level of the electron within the material.
4. Can the Photoelectric effect be explained by classical physics?
No, the Photoelectric effect cannot be explained by classical physics. Classical physics predicts that the energy of a wave is proportional to its amplitude, whereas the Photoelectric effect shows that the energy of a wave is proportional to its frequency. This discrepancy was resolved by Albert Einstein's explanation of the Photoelectric effect through the quantization of light.
5. How is the Photoelectric effect used in modern technology?
The Photoelectric effect is used in a variety of modern technologies, such as solar panels and photodiodes. In solar panels, the Photoelectric effect is utilized to convert sunlight into electrical energy. In photodiodes, the Photoelectric effect is used to detect and measure light, making them useful in light sensors, cameras, and optical communication devices.
  • Quantum Physics
  • Quantum Physics
