Max Ball Height: No Mass Needed
  • Thread starter jaron
In summary, the maximum height of a ball thrown upwards with an initial velocity of 10.0 m/s, neglecting friction, is 5.1m. This is found by equating the kinetic and gravitational potential energy and solving for height. The mass of the ball does not need to be known because it cancels out in the equation, and gravity accelerates all masses equally. The only force acting on the ball is gravity, making mass irrelevant in this situation.
jaron
23
you throw a ball directly upward, giving it an initial velocity of 10.0 m/s. neglecting friction, what would be the maximum height of the ball? (explain why you do not need to know the mass of the ball)
now the problem itself i understand.
we need Eg=mgh, Ek=1/2mv^2
Ek=Eg
1/2mv^2 = mgh
1/2v^2 = gh
1/2(10.0)^2 = 9.81h
50/9.81 = h
h = 5.1m
i understand that we do not have mass and so it must cancel out, but i am confused as to why we do not need to know the mass?
What falls faster a feather or a cannon ball? (this problem assumes 0 resistance)
neglecting air friction, neither..
meaning mass doesn't matter
So you're saying that gravity accelerates all masses in an equal manner. This is correct. What is the one force acting upon the ball after you release it?
only gravity (in this instance because it says to neglect friction)
Yes, do you understand now why you don't need to know the mass of the ball?
i understand.
thank you
Related to Max Ball Height: No Mass Needed
1. How does "Max Ball Height: No Mass Needed" work?
The concept of "Max Ball Height: No Mass Needed" is based on the principle of conservation of energy. This means that the total energy of a system remains constant. In this case, the energy of the ball is converted into potential energy as it is thrown upwards, and then back into kinetic energy as it falls back down. The maximum height the ball can reach is determined by the initial velocity of the throw and the force of gravity.
2. Is it really possible to achieve maximum ball height without using any mass?
Yes, it is possible to achieve maximum ball height without using any mass. This is because the force of gravity acts on the mass of the ball, not the mass of the thrower. As long as the initial velocity and angle of the throw are sufficient, the ball will reach its maximum height without any additional mass.
3. What factors affect the maximum height of the ball?
The maximum height of the ball is affected by the initial velocity of the throw, the angle at which it is thrown, and the force of gravity. Other factors such as air resistance and the surface on which the ball is thrown may also have an impact.
4. Can the maximum ball height be calculated?
Yes, the maximum ball height can be calculated using the equations of motion and the principles of conservation of energy. However, factors such as air resistance and the surface on which the ball is thrown may make the calculation more complex.
5. Is the concept of "Max Ball Height: No Mass Needed" applicable to all objects?
Yes, the concept of "Max Ball Height: No Mass Needed" is applicable to all objects. This is because the principles of conservation of energy and the laws of motion apply to all objects, regardless of their mass or size.
