Elastic and inelastic collisions
In summary, elastic collisions are collisions where kinetic energy is not lost to other forms of energy or heat, while inelastic collisions are collisions where kinetic energy is lost. The objects sticking together is not a requirement for an inelastic collision. The amount of kinetic energy lost and the motion of the objects after the collision depends on the material, internal structure, and shape of the objects. There are varying degrees of elasticity and inelasticity in collisions.
member 529879
I was looking up elastic and inelastic collisions and found that and elastic collision is a collision where kinetic energy isn't lost to other forms of energy or heat while an inelastic collision is just the opposite. In physics class we were taught that an elastic collision was a collision of two object without any sticking while an inelastic collision is a collision of two object where they stick together and become one mass. What is the relation between these two things?
Can you show that if the two objects stick together, given that momentum is conserved, they can't possibly conserve Kinetic energy? Only if the two objects bounce off each other, is it possible to conserve both kinetic energy and momentum.
Likes member 529879
Oh okay that makes sense, but what if two masses of the same value move toward each other at the same velocity and then bounce off of each other going at a lower speed. In this situation, the kinetic energy decreases but the two objects don't stick together. Would this be an elastic or inelastic collision?
Collisions (macroscopic ones, that is) are never perfectly elastic (for instance, if you can hear it, then some of the energy has been converted to sound energy). An inelastic collision is simply a collision in which kinetic energy is not conserved. The objects sticking together is not a requirement. The case you describe is inelastic, as kinetic energy is not conserved. A collision in which the two bodies stick together is actually called a perfectly inelastic collision.
You are thinking perhaps of the Mythbusters episode in which wrecking balls were used as a large version of Newton's Cradle? This is an inelastic collision. Some of the original energy has been dissipated in the permanent deformation of the wrecking balls due to the forces in the collision exceeding the elastic limit of the rather pedestrian iron alloy of the wrecking balls.
Another example. Serious car crashes are inelastic, while slight bumps (no damage) are elastic.
Physical chemists/chemical physicists talk about inelastic collisions between molecules, atoms, etc.
For example, He + H2 (v=0, J=0) ----> He + H2 (v=1, J=2)
There is no sticking, but the internal energy of H2 has changed. You can also see this in atomic systems, and in nuclear collisions. In all of these cases, translational motion/energy has been converted into internal energy of one of the collision partners (or vice versa). In the H2 case above, vibrational and rotational energy of the H2 has changed.
An elastic collision for the example above would be He + H2 (v=0, J=0) ---> He + H2 (v=0, J=0) [no change of internal state of the H2]
Likes swintarka
There are varying degrees of "elastic" or "inelastic". A "perfectly elastic" collision would be one in which NO kinetic energy was lost to other forms of energy. A "perfectly inelastic" collision is one where the two objects stick together and the maximum amount of kinetic energy is lost (can you show that this is the maximum, given momentum must be conserved? There's a trick to make this easier). In the situation described, the collision would be "not perfectly elastic". But it is not "perfectly inelastic" either. It is somewhere in between. Terminology wise, we probably would call it an "inelastic collision" because a good amount of kinetic energy was lost.
Likes member 529879 and Bystander
A distinction too often overlooked in the heat of helping.
Oh ok I got it now, thanks. I do have one final question though. What determines how much kinetic energy will be lost in a collision and how the object will be moving after the collision given the momentum of the objects? Is it the material that the colliding objects are made of?
Material but also internal structure and general shape. So there is no simple way to compute this in general. Usually empirically determined coefficients are used:
http://en.wikipedia.org/wiki/Coefficient_of_restitution
Related to Elastic and inelastic collisions
1. What is an elastic collision?
An elastic collision is a type of collision in which the total kinetic energy of the system is conserved. This means that the total energy before the collision is equal to the total energy after the collision.
2. What is an inelastic collision?
An inelastic collision is a type of collision in which the total kinetic energy of the system is not conserved. Some of the kinetic energy is converted into other forms of energy, such as heat or sound.
3. How do you calculate the velocity of two objects after an elastic collision?
In an elastic collision, the velocities of the two objects can be calculated using the conservation of momentum and the conservation of kinetic energy equations. The equations are as follows:
Momentum: m1v1i + m2v2i = m1v1f + m2v2f
Kinetic Energy: 1/2m1v1i2 + 1/2m2v2i2 = 1/2m1v1f2 + 1/2m2v2f2
Where m is the mass and v is the velocity of each object before and after the collision.
4. What is the coefficient of restitution?
The coefficient of restitution is a measure of the elasticity of a collision. It is defined as the ratio of the relative velocity of separation to the relative velocity of approach. In other words, it is a measure of how much kinetic energy is conserved in a collision.
5. What are some real-life examples of elastic and inelastic collisions?
Examples of elastic collisions include a ball bouncing off a wall, a pendulum swinging back and forth, and a car collision in which there is no damage to the vehicles. Examples of inelastic collisions include a ball hitting and sticking to a wall, a pendulum coming to a stop due to friction, and a car collision in which there is damage to the vehicles.
  • Mechanics
  • Mechanics
