Elastic and Inelastic neutrons scattering
In summary, in order to find the energy lost by a neutron in elastic and inelastic scattering, one must consider its isotropic scattering in the center of mass. For elastic scattering, conservation of momentum and kinetic energy can be used to calculate the energy lost, taking into account the angle after collision. In the case of inelastic scattering, the amount of kinetic energy lost depends on the type of nuclide and the initial energy of the neutron, with information readily available for reference.
Nucengable
42
Elastic and Inelastic neutrons scattering..!
How I can find the energy lost by the neutron in elastic scattering and inelastic scattering, if we assumed its isotropic scattering in the center of mass?
If its elastic, then conservation of momentum and kinetic energy will give you the result. There is one degree of freedom - the angle after collision.
For inelastic scattering you need the amount of kinetic energy lost to exciting the target. That is a function of the nuclide and the neutron energy - there is information available.
http://www.mcs.anl.gov/events/workshops/nprcsafc/Presentations/Oblozinsky%20afc-1%20plenary.pdf
Related to Elastic and Inelastic neutrons scattering
1. What is elastic neutron scattering?
Elastic neutron scattering is a type of scattering that occurs when a neutron interacts with a target nucleus or atom and is scattered off in a different direction without losing energy. This is also known as coherent scattering, as the wavelength and energy of the neutron remain unchanged after the interaction.
2. How does elastic neutron scattering differ from inelastic neutron scattering?
Inelastic neutron scattering is a type of scattering that occurs when a neutron interacts with a target nucleus or atom and transfers energy to the nucleus, causing it to vibrate or excite to a higher energy state. This results in a change in the wavelength and energy of the neutron after the interaction.
3. What information can be obtained from elastic and inelastic neutron scattering experiments?
Both elastic and inelastic neutron scattering experiments can provide information about the structure and dynamics of materials at the atomic level. Elastic scattering can determine the position of atoms in a crystal lattice, while inelastic scattering can reveal information about the vibrational and magnetic properties of materials.
4. How is neutron scattering used in research and technology?
Neutron scattering is a powerful tool used in a wide range of scientific research and technology. It is commonly used to study the structure and behavior of materials in fields such as physics, chemistry, biology, and materials science. It is also used in the development of new technologies, such as nuclear reactors and nuclear weapons.
5. What are some examples of real-world applications of elastic and inelastic neutron scattering?
Elastic and inelastic neutron scattering have many applications in industry, medicine, and research. For example, they are used in the development of new materials for electronics, transportation, and energy production. In medicine, they are used to study the structure of proteins and to develop new drugs. In research, they are used to study the behavior of materials under extreme conditions, such as high pressures and temperatures.
