Elastic attached to a Car travelling down an inclined plane....
In summary, the conversation discusses an experiment involving a car of varying weights traveling down an inclined plane attached to an elastic cord. The distance traveled by the car downward and upward is measured to determine the effects of weight and angle on the rebound distance. The question is posed about the physics theories surrounding this experiment and the individual's theory predicts a parabolic shape on a graph with the optimal weight and angle at the peak. The suggestion is made to test this theory by changing one variable at a time and plotting the results.
Samil
Moved from a technical forum, so homework template missing
Hey!
I'm conducting an experiment wherein a car of various weights travels down an inclined plane of varying angles, attached to the back of the car and the top of the ramp is an elastic cord. Once the car reaches the end the elastic pulls backward, and thus pulling the car back. We are measuring the distance downward from the equilibrium point that the car travels, and how far back above the equilibrium point it travels on rebound.
The Question
What physics theories surround this experiment, and if so please elaborate as to how these affect the results.
My Theory
As the weight and angle increase, the rebound distance will lessen due to the elastic potential energy not being strong enough to pull a car back that is moving at such velocity, thus the data will be placed on a graph in a parabolic shape, with the optimal angle and weight at the peak.
Why don't you test your theory by actually doing the experiment? I suggest that you change only one variable at a time. By this I mean change the weight keeping the angle fixed, then change the angle keeping the mass fixed. Plot your results and see if your theory explains them.
FAQ: Elastic attached to a Car travelling down an inclined plane....
1. What is the purpose of an elastic attached to a car travelling down an inclined plane?
The purpose of an elastic attached to a car travelling down an inclined plane is to measure the force of gravity acting on the car. The elastic stretches as the car moves down the inclined plane, allowing for the calculation of the gravitational force.
2. How does the angle of the inclined plane affect the elastic attached to the car?
The angle of the inclined plane will affect the length of the elastic and the amount of stretching it undergoes. A steeper angle will result in a longer elastic and more stretching, while a shallower angle will result in a shorter elastic and less stretching.
3. Does the mass of the car impact the elastic attached to it?
Yes, the mass of the car will impact the elastic attached to it. A heavier car will result in a greater gravitational force and therefore more stretching of the elastic, while a lighter car will result in a smaller gravitational force and less stretching.
4. Can the elastic attached to a car travelling down an inclined plane be used to calculate the acceleration of the car?
Yes, the elastic can be used to calculate the acceleration of the car using the equation F=ma, where F is the gravitational force measured by the elastic, m is the mass of the car, and a is the acceleration down the inclined plane.
5. How does the surface of the inclined plane affect the elastic attached to the car?
The surface of the inclined plane can affect the friction between the car and the surface, which can impact the accuracy of the elastic's measurement. A rougher surface may result in more friction and a lower acceleration, while a smoother surface may result in less friction and a higher acceleration.
