Elastic collision problem involving nuclei
In summary: It's a tough gap to bridge but I appreciate your help in the matter.Thanks!Yes, you got it. To solve a pair of equations with two variables, you need to eliminate one of them. If you succeed, you get an equation involving just the other variable. Then you can solve that equation for the one variable. Once you have that, you can go back to either of the original equations and get the value of the remaining variable. In this case, you don't want v1', so that's the one to eliminate. In other problems, it might be the other way around. There are some situations where you can't eliminate any variable, but then usually you get
Hoodoo
Two nuclei make a head-on elastic collision. One nucleus (mass m) is initially stationary. The other nucleus has an initial velocity (v) and a final velocity of (-v/5). What is the mass of this nucleus?
conservation of momentum (m1v1+m2v2=m1v1'+m2v2')
conservation of energy (1/2m1v1^2 + 1/2m2v2^2 = 1/2m1v1'^2 + 1/2m2v2'^2)
I've substituted in the knowns and came up with (m2v = mv1' + m2*-v/5)
I isolated for v1' though I'm not really sure why and came up with v1' = (6m2v1)/5m
This is probably totally wrong and I'm not sure why I even did it.
The examples given to me for elastic collision all involve a bunch of substitutions and isolated for variables without any explanation. This question has too many variables for me to keep it straight in my head. I'd love a thorough explanation if anyone has the time. Thanks.
Welcome to PF!
Hi Hoodoo! Welcome to PF! :smile:
(try using the X2 and X2 buttons just above the Reply box :wink:
ok, you don't know v1' (and you don't want to),
so eliminate v1' from those 2 equations to make a single equation without v1' …
show us what you get :smile:
I got:
m = (6m2v)/5)
Now I'm supposed to substitute into the equation for conservation of energy..
I end up at the end with:
0 = v((6m2)/5) - ((24m2v)/25))
Therefore, v = 0 or v = 5/4
Sub back into original equation:
m = (6m2v)/5
m = (6m25)/5*4
m2 = 2m/3
Now, my main question is.. how was I supposed to know to NOT include v1'? My instructors seem to have left this little leap out of the written materials and lectures. It's not mentioned at all in the question.. is that enough of a reason or am I supposed to know this due to the laws?
Hoodoo said:
m = (6m2v)/5)
That's dimensionally wrong. Typo in the post?
m2 = 2m/3
I get the ratio the other way around. I think I'm right because in an elastic collision with a stationary mass, the first mass bounces backwards if and only if it is the lighter of the two. Check the signs in your working.
It's not that you don't include it. Whenever you have multiple equations with shared variables, you'll be wanting to use some of the them to eliminate variables from the others. A question is, which to eliminate? That is directed by knowing which you want in the final equation. In this case, v1' is a good candidate for elimination.
No typo. I get the answer that is given in the text doing what I did. I'm looking for m2. If you get it the other way around, you've already solved the question, haven't you?
0+m2v = m + m2(-v/5)
m = m2v + m2v/5
m = 6m2v/5
I removed v1' entirely instead of eliminating it because I misunderstood the instructions but it worked out in the end.
I still don't know how to KNOW what I'm supposed to eliminate and solve for and this doesn't help.
Dimensionally wrong. m is a mass, the other terms are momenta. The equation is
0+m2v = mv1' + m2(-v/5)
My mistake there - I misread which mass had mass m. I now agree with your answer, if not with the details of how you got there.
Is it possible you don't know what is meant by 'eliminating a variable'?
Given m2v = mv1' + m2(-v/5)
and m2v2 = mv1'2 + m2(v/5)2, you know you want an equation involving m2 and m, and you don't mind if it involves v. m and v were given you, so could validly turn up in the answer. But you certainly know you don't want v1'. So that's the one to eliminate. To do that, you rearrange one equation in the form v1' = something. The first equation is the more convenient since that won't result in a square root:
v1' = m2v/m - m2(-v/5)/m = m2(6v/5)/m
Now use that to substitute for v1' in the other equation:
m2v2 = m(m2(6v/5)/m)2 + m2(v/5)2
A factor m2v2 cancels:
1 = (m2(36/25)/m) + 1/25
m2=2m/3
Is that clearer?
That is a big mistake.. yes I see what you're saying. Completely removing v1' was totally incorrect but I lucked into the answer in the end.
So I should originally isolate the variable that is both unknown and unwanted in the final solution? Then substitute that into the other equation and solve for what I REALLY wanted. That 'eliminates' it?
I find that people that 'get' physics sometimes have a hard time relating simple concepts because they are immediately apparent to them and they have a hard time putting themselves into the shoes of someone that doesn't just 'get it'. Half of my struggle in this subject is explaining what I don't understand to people who find answers and methods simply apparent.
Exactly. This is what you do in solving simultaneous equations, and it's the same process as diagonalising a matrix.
Tell me about it :wink:
FAQ: Elastic collision problem involving nuclei
1. What is an elastic collision involving nuclei?
An elastic collision involving nuclei is a type of collision between two nuclei (the central part of an atom) in which there is no net loss of kinetic energy. This means that the total kinetic energy of the system before and after the collision remains the same.
2. How is the conservation of momentum applied in elastic collisions involving nuclei?
In elastic collisions involving nuclei, the conservation of momentum is applied by stating that the total momentum of the system before the collision is equal to the total momentum after the collision. This means that the sum of the momenta of the two nuclei before the collision is equal to the sum of the momenta after the collision.
3. What are the factors that affect the outcome of an elastic collision involving nuclei?
The outcome of an elastic collision involving nuclei is affected by several factors, including the masses of the nuclei, their initial velocities, the angle of collision, and the forces that act during the collision. These factors determine the final velocities and directions of the nuclei after the collision.
4. How is the coefficient of restitution used to measure the elasticity of a collision involving nuclei?
The coefficient of restitution is a measure of the elasticity of a collision involving nuclei. It is defined as the ratio of the relative velocity of the nuclei after the collision to the relative velocity before the collision. A perfectly elastic collision would have a coefficient of restitution of 1, while a completely inelastic collision would have a coefficient of restitution of 0.
5. Can elastic collisions involving nuclei be used to study nuclear reactions?
Yes, elastic collisions involving nuclei can be used to study nuclear reactions. By observing the final velocities and directions of the nuclei after the collision, scientists can gather information about the forces and energies involved in the collision. This can provide valuable insights into the fundamental properties of nuclear reactions and help in the development of nuclear technologies.
