Elastic Collision w/ Pendulum Bobs
In summary, the problem involves two pendulums of different masses and lengths colliding at the lowest point. The heights to which the bobs rise after the collision are calculated for two scenarios: completely inelastic and perfectly elastic. For the completely inelastic collision, the final potential energy is not equal to the initial one and the calculated heights are incorrect. For the perfectly elastic collision, the final velocity of the lighter mass is not zero and the heights are still incorrect. It is important to consider the conservation of energy and linear momentum when calculating the heights.
paola8
1. A pendulum bob of mass m is released from a height H above the lowest point. It collides at the lowest point with another pendulum of the same length but with a bob of mass 2m initially at rest.
Find the heights to which the bobs rise given that the collision is (A) Completely Inelastic, (B) Perfectly Elastic.
(conservation of linear momentum)
m1u1 + m2u2 = m1v1 + m2v2
(conservation of energy)
.5mv^2 + mgh = .5mv^2 + mgh
initial PE = mgH
= final KE at lowest point
= 0.5 mu^2
total mass = 3m
final PE
= 3m g *h
mgH = 3mg h
h = H/3
***answer is supposed to be H/9??***
mgH= 0.5 mu^2
0.5 *m *u^2 + 0.5 * 2m *0^2 =0.5 * m * 0^2 + 0.5 * 2m * v^2
0.5 *m *u^2 = 0.5 * 2m * v^2
0.5 * 2m * v^2 = mgH
KE of 2m at lowest point = PE at height point
0.5 * 2m * v^2 = 2m g h1
mgH = 2mg h1
h1 = H/2
***answer is supposed to be H/9, and 4H/9??***
Could anyone help me as to why I've got the wrong answers?
Yes, it is a big truth that everything is identical with itself...
paola8 said:
initial PE = mgH
= 0.5 mu^2
total mass = 3m
final PE
= 3m g *h
mgH = 3mg h
You supposed that the final potential energy is equal to the initial one, that is energy is conserved, but it is not true for an inelastic collision.
mgH= 0.5 mu^2
The final velocity of the lighter mass will not be zero: It does not collide with an equal mass. ehild
Related to Elastic Collision w/ Pendulum Bobs
What is an elastic collision?
An elastic collision is a type of collision between two objects where both the kinetic energy and momentum are conserved. This means that the total energy and total momentum before the collision is equal to the total energy and total momentum after the collision.
How does a pendulum bob experience an elastic collision?
A pendulum bob experiences an elastic collision when it collides with another object or surface and bounces off without any loss of energy. This is possible because the pendulum bob is attached to a string, which can stretch and compress to absorb the impact of the collision.
What factors affect the elastic collision of pendulum bobs?
The speed and mass of the pendulum bobs, as well as the angle at which they collide, can affect the elastic collision. The elasticity of the string and the surface the pendulum bob collides with can also impact the collision.
How is the coefficient of restitution related to elastic collision of pendulum bobs?
The coefficient of restitution is a measure of the elasticity of a collision. In the case of pendulum bobs, a higher coefficient of restitution indicates a more elastic collision, where the kinetic energy is conserved. A lower coefficient of restitution means the collision is inelastic, with some energy being lost during the collision.
What are some real-life applications of elastic collision with pendulum bobs?
Elastic collisions with pendulum bobs are commonly seen in sports such as billiards, where the balls collide and bounce off each other. They are also used in engineering and physics experiments to demonstrate the conservation of energy and momentum. Pendulum bobs are also used in amusement park rides, such as the Newton's Cradle, to show the principles of elastic collisions in action.
