Elastic collisions of particles
In summary, Homework Equations state that the total kinetic energy is conserved in an elastic collision and that the speed of the particle after impact is U/2.
accountdracula
Three particles, A, B, and C, with masses M, 2M, and 3M respectively, lie at rest in that order in a straight line on a smooth horizontal table. The particle A is then projected directly towards B with velocity U.
Assuming the collisions are perfectly elastic, I need to find the fraction of U that C moves with, immediately after impact.
2. Homework Equations [/B]
I used the idea that kinetic energy is conserved in a perfectly elastic collision:
0.5 * M * U^2 = 0.5 * 2M * kU^2
1 = 2k
k = 1/2
Therefore the speed of B after impact is U/2
0.5 * 2M * (U/2)^2 = 0.5 * 3M *kU^2
2(U^2/4) = 3kU^2
U^2/2 = 3kU^2
1 = 6k
k = 1/6
It asks for the answer as a decimal to three significant figures, so I've typed in: 1.67 x 10^-1 but it's not having it. Where have I gone wrong?
Thanks for your help in advance.
[edit] I wrote it down wrong.
Total kinetic energy is conserved in an elastic collision. You tried (and got wrong) having the kinetic energy in the first collision completely pass to mass B. With twice the mass and half the speed, what is the kinetic energy?
In an elastic collision both total momentum and kinetic energy are conserved. You must use both.
The easy way to do collisions of this sort is in the centre of momentum frame. Before the collision you have two particles coming in with opposite momentums. After they just "reflect" so their momentums just change sign. Then you transform back to the lab frame.
Thanks for your reply.
I'm confused about what you've told me, however. How would I use both the conservation of momentum and kinetic energy to answer this? I can't see how it's necessary. Surely if you know that both momentum or kinetic energy is conserved because it is a series of elastic collisions, you can solve this considering only one of them?
I tried this again, considering momentum:
M * U = 2M * kU
1 = 2k
We have the second particle B, with half the speed, is that not right?
2M *U/2 = 3M * kU
1 = 3k
k = 1/3
However I get a different answer for this one. I'm really confused. I think you may have misunderstood the situation I described "Before the collision you have two particles coming in with opposite momentums." I meant all three balls are at rest, then A is projected and hits B, B then goes on to hit C.
You now have the second particle going half the speed of the first one. That means the second particle has the full momentum of the first one before the collision. That means the first one has to have stopped to conserve momentum. But what is the kinetic energy of the second particle? Is it the same as the first one before the collision?
You must conserve both momentum and energy. You have not done that. The easy way to do that is in the centre of momentum frame.
https://en.wikipedia.org/wiki/Center-of-momentum_frame
But if you don't like the COM frame, fine.
Before the first collision you have particle mass M moving at U. That means you have a momentum MU, and a kinetic energy 1/2 M U^2. After the collision you will have the particle mass M going at some other speed, call it V1 and particle mass 2M going at some new speed, call it V2. Use positive values to be in the same direction as the original, in case they wind up flipping. You have a total momentum after.
M V1 + 2 M V2
And a total kinetic energy after.
1/2 M V1^2 + 1/2 2 M V2^2
And the after momentum has to be the same as the before momentum of MU. And the after kinetic energy has to be the same as the before of 1/2 M U^2. That's two equations in two unknowns. Solve for V1 and V2.
If this is all completely unfamiliar, then you need to go read your notes again. Or your text.
But it is WAY easier to transform to the COM frame. In that frame, as I said, yada yada, equal but opposite momentums just reflect in an elastic collision.
Thanks for your patience, I've never learned about momentum in this much depth before. Some of this is completely new to me. I now understand why I need to combine the two equations in elastic collisions.
I don't understand the COM you mentioned, that looks too complicated for me? So I'll work with the equations.
Basically I did this:
U = V1 + 2V2
U^2 = 2V2 ^2 + V1 ^2
V1 ^2 + 4V1V2 + 4V2 ^2 = 2V2 ^2 + V1 ^2
4V1V2 + 2V2 ^2 = 0
V2(4V1 + 2V2 ^2) = 0
Is this alright so far?
Please help me, someone.
This is my latest attempt:
Where V1, V2, and V3 are the final velocities of particles of masses M, 2M, 3M respectively,
Momentum is conserved:
(1) MU = MV1 + 2MV2
U = V1 + 2V2
As is KE:
0.5* MU^2 = (0.5 * MV1^2) + (0.5* 2MV2)
(2) U^2 = V1^2 + 2V2^2
Making V1 the subject of equation (1) and subbing it into (2):
U^2 = (U - 2V2)^2 + 2V2^2
U^2 = U^2 - 4V2U + 6V2^2
4V2U - 6V2^2 = 0
V2(4U - 6V2) = 0
V2 =/= 0
4U = 6V2
V2 = 4/6U
: The velocity of particle 2 is 2/3 of that of the first before impact, in the same direction.
Where V4 is the velocity of the particle with mass 2M, after its impact with particle of mass 3M and V3 is still the velocity of particle 3M :
Momentum:
2M 2/3 U = 2MV4 + 3MV3
(1) 4/3 U = 2V4 + 3V3
KE:
0.5 * (2/3U)^2 *2M = 0.5 * 2MV4 ^2 + 0.5* 3MV3 ^2
(2) 8/9 U^2 = 2V4 ^2 + 3V3 ^2
Rearranging (1) for V4 and subbing into (2) =
8/9 U^2 = 2(2/3U - 3/2 V3)^2 + 3V3 ^2
8/9 U^2 = 2(4/9U^2 - 12/5 V3U + 9/4V3^2) + 3V3^2
8/9 U^2 = 8/9 U^2 - 12/5 V3U + 21/4 V3^2
12/5 V3 U - 21/4 V3^2
V3(12/5U - 21/4 V3) = 0
V3 =/= 0
12/5U = 21/4 V3
12/5 * 4/21 U = V3
48/105 U = V3
V3 is 0.457 (3 s.f) of that of the velocity of U.
I know the way I've typed this out is really hard to understand, but if someone could try I'd be super grateful.
Related to Elastic collisions of particles
1. What is an elastic collision?
An elastic collision is a type of collision between particles where no kinetic energy is lost. This means that the total kinetic energy of the particles before and after the collision remains the same.
2. How are elastic collisions different from inelastic collisions?
In elastic collisions, the total kinetic energy of the particles remains the same, while in inelastic collisions, some kinetic energy is lost. Inelastic collisions often result in a change in the shape or structure of the colliding particles.
3. What factors affect the outcome of an elastic collision?
The outcome of an elastic collision is affected by the mass, velocity, and angle of the colliding particles. The more similar the masses and velocities of the particles, the more elastic the collision will be.
4. Can elastic collisions occur in real-life situations?
Yes, elastic collisions occur in many real-life situations, such as billiard balls colliding on a pool table or molecules colliding in a gas. However, it is difficult to achieve a completely elastic collision in real-life as there is always some energy lost due to friction or other external factors.
5. How is the conservation of momentum applied in elastic collisions?
In elastic collisions, the total momentum of the particles before and after the collision remains the same. This is known as the conservation of momentum and is a fundamental principle in physics that is applied in many different situations, including elastic collisions.
