R.H.2010
- 6
Particle 1 of mass 230 g and speed 2.80 m/s undergoes a one-dimensional collision with stationary particle 2 of mass 400 g.
What is the magnitude of the impulse on particle 1 if the collision is elastic?
What is the magnitude of the impulse on particle 1 if the collision is completely inelastic?
For the 1st Question, i found final velocity for particle 1, so that I can subtract the given initial velocity for particle 1 to get the impulse. i used this equation: v'1 = v1 (m1 - m2) / (m1 + m2), noting that initial velocity for particle 2 is zero ( as given ) and then I plugged in numbers and got -.755555
Then I went back to equation for change in momentum: m1v'1 - m1v1 and got -817.7778 however this is wrong.
for the 2nd Question
I used: m1v1 + m2v2 = m1v'1 + m2v'2 , noting that m2v2 is zero ( as given v2 is zero ) and the m1v'1 = m2v'2 because they has to move together since they stick together. but Now i have two unknowns ( v'1 and v'2 ) and only 1 equation. I don't know how to solve it?
m1: mass for particle 1
m2: mass for particle 2
v1: initial velocity for particle 1
v2: initial velocity for particle 2
v'1: final velocity for particle 1
v'2: final velocity for particle 2
Thank you.
