Elastic Section Modulus vs Moment of Inertia
In summary, moment of inertia and elastic section modulus are two different concepts that are often confused with each other. Moment of inertia is related to the distribution of mass in a body and is used to calculate dynamics, while elastic section modulus is related to the distribution of area in a structural section and is used to calculate bending stress. While both are important in structural engineering, they serve different purposes and cannot be used interchangeably.
Peter10
Hi everyone!
Please help, I have spent a considerable time to understand the two concepts and still this is nagging at me... I am relating to Structural Engineering, just to let you know guys. My question is ..
Moment of inertia is about distribution of mass, the further away from the axis the higher the resistance to applied moment ( I believe I know the concepts of angular acceleration and etc.). Likewise in case of Elastic Section Modulus if the distribution of area of section is larger away from the axis the resistance to elastic deformation is greater... So in terms of Structural Engineering what is the difference between the two? I know that moment of inertia is related to mass (althou it is in cm^4 which is brings another question, why is it not in kg?), but as in practical sense why do we need one or the other to determine the strength of the beam, let's say up to elastic limit?
You are looking for area moment of inertia in units of length^4 , not to be confused with the mass moment of inertia. Area moment of inertia is a property of the shape and area distribution. Bending stress My/I is not dependent on the E modulus. Bending strain is My/EI . You can have 2 similar beams of the same shape and length and loading etc but of different materials, and the bending stress will be the same in either case, but the bending strains and deflections will not. In regard to the elastic stress limit, that is not a function of either E or I.
Peter10 said:
Hi everyone!
You are confusing two different concepts, namely the second moment of area and the mass moment of inertia, which are unfortunately and inaccurately known by the grab-all term "moment of inertia".
Let's take the "mass moment of inertia" of a body first.
We know from Newton's laws of motion that it takes a certain applied effort to change the motion of a body. For bodies in rectilinear motion, the equation F = ma describes how the acceleration of a body of mass m will change when a certain external force F is applied.
For bodies in rotational motion, the corresponding equation is T = J α, where J is the mass moment of inertia of the body (and which has units of ML2) and α is the angular acceleration (units of radians per second2) produced by the applied torque T (units of force times distance, or M × L × T-2 × L = ML2T-2). The mass moment of inertia J is an intrinsic property of the body, the value of which is influenced by the distribution of mass about the center of gravity.
The mass moment of inertia is used to calculate the dynamics of bodies undergoing motion.
The other moment of inertia, the second moment of area, is the one which is most commonly encountered in structural engineering. The second moment of area, usually denoted as I, arises from studying the bending of beams. The bending stress σ in a beam is given by the equation σ = M y / I, where M is the applied bending moment, y is the distance from the neutral axis to where the bending stress is sought, and I is the second moment of area of the cross section of the beam. This inertia is roughly analogous to J in that it describes the distribution of section area about the centroid of the section. The units of I are A × L2 (compare the units of J = M × L2), which is why tables of structural properties have units like cm4.
In beam analysis, the maximum bending stress is encountered at the outer fiber of the beam, which is located at the greatest distance from the neutral axis.
Thus for a given structural section, I can be calculated and y is known from the geometry, so the bending stress formula can be re-written as σ = M / SM, where SM is the section modulus of the beam cross section and SM = I / y (units of L3. By knowing the section modulus of a beam at a given location, it is thus a simple calculation to find out how much bending moment will produce a given level of bending stress. If you take a beam with a limiting elastic stress σ, then the maximum bending moment is M = σ × SM.
Thank you guys for your explanations. I am aware of the fact that section modulus it for computing maximum stress within elastic limit. However
1. As elastic modulus is also dependant on the area distribution and distance from the neutral axis ,it quantifies the ' resistance' of the beam to bending just as second moment of area?
2. I read somewhere that elastic modulus is the same as first moment of area( well if Second Mom. of Area is A^2/y^2 and we divide it by y we get A^2/y,,, the same as first moment of area?
Stronger beams generally tend to have numerically greater second moments of area, since SM = I / y. More than anything, the SM is typically used to simplify the calculation of bending stress a little, or to compare the strength of two or more different beam cross sections.
Although the section modulus SM = I / y has the same units as the first moment of area, it should not be confused with being the same quantity as the first moment of area. Doing some simple calculations for various types of structural sections should confirm this.
Thank you!
Related to Elastic Section Modulus vs Moment of Inertia
1. What is the difference between Elastic Section Modulus and Moment of Inertia?
The elastic section modulus and moment of inertia are both important properties used to analyze the strength and stiffness of a structural member. The main difference between the two is that the elastic section modulus is a measure of a cross section's resistance to bending, while the moment of inertia is a measure of its resistance to both bending and torsion.
2. How are Elastic Section Modulus and Moment of Inertia calculated?
The elastic section modulus is calculated by dividing the moment of inertia of a cross section by the distance from the neutral axis to the outermost fibers. The moment of inertia is calculated by summing the products of each infinitesimal area in the cross section and its squared distance from the neutral axis.
3. Which property is more important for structural design?
Both the elastic section modulus and moment of inertia are important for structural design, as they provide information about a member's ability to resist bending and torsion. However, the elastic section modulus is often the more critical property, as most structural members are designed primarily for bending loads.
4. Can Elastic Section Modulus and Moment of Inertia be changed?
Yes, both properties can be changed by altering the cross sectional shape of a member. For example, increasing the depth of a beam will increase its moment of inertia, making it stiffer and more resistant to bending. Similarly, changing the distribution of material in a cross section can also affect the elastic section modulus.
5. What is the significance of Elastic Section Modulus and Moment of Inertia in real-life applications?
These properties are crucial in the design and analysis of various structures, such as buildings, bridges, and mechanical components. They help engineers determine the appropriate size and shape of structural members to ensure safety and stability under different loading conditions. They also play a role in material selection, as materials with higher elastic section moduli and moment of inertia are more suitable for high-stress applications.
  • Classical Physics
