Elastomer stretched in tension and elongation
In summary, the problem involves a strip of elastomer being stretched in tension and held constant for 10 minutes. The tensile stress in the specimen drops by 12% and we are asked to calculate the relaxation time using the maxwell model equation. We are also asked to show that it takes 22 minutes for the stress to drop to 75% of its final value. The ratio of sigma(t) / sigma(0) needs to be determined when t=10 minutes.
tone999
A strip of elastomer was stretched in tension and elongation and was held constant. After 10 minutes the tensile stress in the specimen dropped by 12%. Assuming that the elastomer behaves in accordance with the maxwell model:
(i) Calculate the relaxation time (to the nearest whole number)
(ii) Show that it takes 22 minutes for the stress to drop to 75% of its final value.
I take it we have to use the maxwell model equation here?
sigma (t) = sigma (0) e ^ -t/tau
I think so. Based on the information in the problem statement, what is the ratio,
sigma(t) / sigma(0),​
when t=10 minutes?
(i) To calculate the relaxation time, we can use the given information that after 10 minutes, the tensile stress dropped by 12%. This means that the final stress is 88% of the initial stress, or 0.88*sigma(0). Plugging this into the maxwell model equation, we get:
0.88*sigma(0) = sigma(0) e ^ -10/tau
Solving for tau, we get tau = 11.7 minutes, which can be rounded to 12 minutes.
(ii) To show that it takes 22 minutes for the stress to drop to 75% of its final value, we can use the same equation and plug in the given values. We know that after 10 minutes, the stress is at 88% of its initial value, so we can use this as our new initial stress, or sigma(0). We also know that we want to find the time it takes for the stress to drop to 75% of this value, or 0.75*0.88*sigma(0). Plugging this into the equation, we get:
0.75*0.88*sigma(0) = 0.88*sigma(0) e ^ -t/12
Solving for t, we get t = 22 minutes, which confirms that it takes 22 minutes for the stress to drop to 75% of its final value. This makes sense, as the relaxation time is the time it takes for the stress to drop to 37% of its initial value, and 75% is almost double that value.
Related to Elastomer stretched in tension and elongation
1. What is an elastomer?
An elastomer is a type of polymer that has the ability to stretch and return to its original shape. It is often referred to as a rubber-like material due to its flexibility and resilience.
2. How is an elastomer stretched in tension?
Elastomers can be stretched in tension by applying a force or load in one direction. This causes the polymer chains to align and elongate, creating a strain on the material.
3. What is elongation?
Elongation refers to the percentage increase in length of an elastomer when stretched. It is the measurement of how much the material can be stretched before it reaches its breaking point.
4. What factors affect the tensile strength of an elastomer?
The tensile strength of an elastomer can be affected by several factors including the type of polymer used, the amount of cross-linking between polymer chains, and the temperature at which it is stretched.
5. What are some common applications of elastomers?
Elastomers have a wide range of applications in various industries such as automotive, construction, and medical. They are commonly used in tires, seals, gaskets, and medical devices due to their flexibility, durability, and chemical resistance.
11K
11K
  • Classical Physics
