Is Distributed Electric Propulsion the Key to Efficient Private Planes?
In summary, NASA has released a press release today highlighting its electric aviation program with a new 4-seat X plane. The goal of this program is to reduce the power requirements of a private plane to cruise at 175 mph, which is an interesting goal but ill-considered in my opinion. If you can do the same for 1/n of the power then you can do it for n times longer, which increases range by a factor n. The arrangement shown has a very high aspect ratio with very even airflow from the props over the wing, which should give an exceptional lift to drag ratio.
mheslep
729
NASA has press release out today highlighting its electric aviation program via a new 4-seat X plane to explore the concept, the X-57.
Most interesting to me was this claim:
NASA’s aeronautical innovators hope to validate the idea that distributing electric power across a number of motors integrated with an aircraft in this way will result in a five-time reduction in the energy required for a private plane to cruise at 175 mph.
which I imagine comes about by having a much large propulsive air flow area across the 14 e-motors, allowing the prop flow velocity to be much lower.
Goal:
NASA researchers ultimately envision a nine-passenger aircraft with a 500-kilowatt power system in 2019. To put that in perspective, 500 kilowatts (nearly 700 horsepower) is about five times as powerful as an average modern passenger car engine
That goal is interesting but ill-considered IMO, as range is the issue in electric aviation, not power.
Video of fourteen motor wing under test
If you can do the same for 1/n of the power then you can do it for n times longer. That increases range by a factor n.
Likes mheslep and FactChecker
That is one optional benefit. It also could allow you to loiter in place and observe for a long time, even if the cruse speed is decreased. It might even allow sustained solar-powered flight where the plane can stay up indefinitely.
Point taken.
Aside: I don't see efforts at many-motor designs among RC electric aircraft hobbyists, or in the UAV arena. Perhaps cost is an issue, though since the RC's with their LiPos are quite range (time aloft) limited, say, 15 mins, there should be ample motivation to try. Edit: here's a competition for time aloft (traditional design) with a maximum of 26 mins.
FactChecker said:
.. It might even allow sustained solar-powered flight where the plane can stay up indefinitely.
Overnight unmanned electric flight was accomplished six years ago. http://tucson.com/business/local/tucson-firm-s-solar-batteries-power-record-flight-attempt/article_00ec5266-f412-5b3d-aaa5-04e9d87ec896.html made by QinetiQ with Sion batteries flew non-stop for 14 days using PV: dual prop, 70 ft wingspan, 110 lbs. The term of art going forward is "solar powered atmospheric satellites"
http://www.unmannedsystemstechnolog...for-solar-powered-atmospheric-satellite-uavs/
Likes FactChecker
Presumably the idea behind multiple motors and props is to increase the air flow over the wing meaning a smaller wing can be used?
I don't think so. There's some work on a design indicating lower turbulence with aft fuselage mounted engines thus reducing drag by positioning motors in places not practical with combustion engines.
But as I understand it, the principal advantage of multiple motors is that they are theoretically more efficient than one at producing the same amount of total thrust. That is , thrust is proportional to both air velocity and the area through which the air is driven, but high velocity exit air is wasted kinetic energy in the atmosphere. Thus it is more efficient to achieve thrust by greater engine area when possible than by higher velocity air flow.
Likes CWatters and FactChecker
The arrangement shown has a very high aspect ratio with very even airflow from the props over the wing. That should give an exceptional lift to drag ratio.
FAQ: Is Distributed Electric Propulsion the Key to Efficient Private Planes?
1. What is electric aviation?
Electric aviation is the use of electric power to propel aircraft instead of traditional fossil fuels. This can include fully electric aircraft, or hybrid aircraft that use a combination of electric and traditional engines.
2. Why is electric aviation important?
Electric aviation is important for several reasons. First, it has the potential to reduce carbon emissions and contribute to the fight against climate change. Second, it can help reduce noise pollution, as electric engines are quieter than traditional ones. Finally, it has the potential to lower operating costs for airlines in the long run.
3. How developed is electric aviation currently?
While electric aviation is still in its early stages, there have been significant developments in recent years. Several companies have successfully tested fully electric aircraft, and many major aircraft manufacturers have announced plans to develop electric or hybrid planes. However, there are still challenges to overcome before electric aviation becomes mainstream.
4. What are the challenges facing electric aviation?
One of the main challenges facing electric aviation is the limitations of battery technology. Batteries are currently heavy and have limited energy storage, which can limit the range and payload of electric aircraft. Another challenge is the development of infrastructure to support electric aviation, such as charging stations and power grids. There are also regulatory and safety concerns that need to be addressed.
5. What is the future of electric aviation?
The future of electric aviation looks promising. With advancements in battery technology and increased investment in research and development, it is likely that we will see more electric and hybrid aircraft in the skies in the coming years. However, it will likely take some time before electric aviation becomes the norm and replaces traditional fossil fuel-powered aircraft entirely.
