Electric Bicycle with no Battery
In summary, the conversation discusses the idea of using a generator at the pedal to directly conduct electricity to a wheel motor, eliminating gears and a chain. The efficiency of such a system is estimated to be between 55% and 70%, and it may behave as an automatic gear reducer when going uphill and vice versa when going downhill. However, this system is not as efficient as a straight chain drive, and adding a battery can provide more flexibility.
viper252
Hello, I am curious if this has been done, or would even be worthwhile.
The idea would be to use a generator at the pedal and conduct the electricity directly to a wheel motor with no power storage. This would eliminate gears and a chain. Does anyone know what the approximate efficiency of such a system would be?
How would this drive system behave when going up a steep hill? Would it act as an automatic gear reducer and vice versa when going downhill?
Likes AlexCaledin
I've seen similar experiments where students pedal on a bike to drive various electrical appliances and as more are added to the circuit it become difficult if not impossible to pedal because of the load.
Here's a DIY project on it:
Its cool but not as efficient as a straight chain drive. You can add a battery into the mix for more flexibility when you get tired of pedaling and that is the primary advantage over a straight chain drive.
Likes AlexCaledin and viper252
absolutely. It's no surprise that the basics of the bicycle haven't changed since they introduced chain drive. With the fantastic number of ratios available on a bike, an infinitely variable gearing is hardly worth considering.
I would anticipate the generator and motor being 80-90% efficient at best. You would also need some sort of DC-DC converter/regulator/optimiser to replicate the effect of gears. That might be 90% efficient at best? So overall somewhere between say 55% and 70% overall? Your mileage may vary.
Related to Electric Bicycle with no Battery
What is an electric bicycle with no battery?
An electric bicycle with no battery is a type of bicycle that uses a different power source, such as pedaling or solar power, to operate instead of a traditional battery-powered motor.
How does an electric bicycle with no battery work?
The specific mechanics of an electric bicycle with no battery can vary, but generally, it operates by using a different power source, such as pedaling or solar power, to turn a motor that then propels the bicycle forward.
What are the benefits of an electric bicycle with no battery?
One of the main benefits of an electric bicycle with no battery is that it is environmentally friendly, as it does not require the use of fossil fuels. Additionally, it can be more cost-effective than traditional electric bicycles, as there is no need to replace or charge a battery.
Are there any limitations to an electric bicycle with no battery?
Yes, there are some limitations to an electric bicycle with no battery. Depending on the power source used, the range and speed of the bicycle may be limited. Additionally, it may not be suitable for certain terrains or riding conditions.
Is an electric bicycle with no battery legal to use?
The legality of an electric bicycle with no battery can vary depending on the location. It is important to check with local laws and regulations before operating one. In some places, it may be considered a traditional bicycle, while in others it may require registration or a license.
  • Electrical Engineering
  • DIY Projects
  • Mechanics
