Electric charge and potential energy
In summary: If will help if you state...If you are moving the charge from a great distance, then Eqd would be the appropriate equation to use.
brake4country
216
A particle with charge q experiences a force F when placed a distance d from a point charge. At a distance d, the electric field has a strength E and a potential V. Which of the following represents the potential energy of the charge?
(A) Fd
(B) Eqd
(C) Vq
(D) Ed
U=Eqd; U=kq1q2/r; V = Ed; V = kq1/r.
I chose B but the correct answer is C. We know that the potential energy of a charge in an electric field is the force times the displacement: U = Eqd. What is the difference between answer choice B and C? Thanks in advance and if I didn't provide enough explanation for my question, please let me know.
The voltage has units of Volt or, what we are interested in is Joule per Coulomb so V.q has units of Joule, which can be energy, but also B) proposes a result with unit of Joules, so what's the difference ?
Well, The ELECTRIC potential energy is a potential energy, it just depends on you distance to the source of electric field and by displacing the charge as B) proposes, you increase it's PE, or give it any form of energy, what I mean if d = r (the distance btw the charge) then B) would be true and in either case C) is the most general and the right one, Hope I've made it a little bit clearer and good luck .
Right. When I look at the units for B and C, I notice they are both in Nm = J. However, can you clarify when to use U = Eqd and U = Vq? My book states that Eqd is the potential energy or work done, which makes sense but I cannot see how they get U =Vq. Thank you.
The equation U = Vq is valid in general. The expression Eqd is used for the case of a charge q in a uniform electric field. Usually one writes ΔU = -Eqd where d is the distance the charge q moves parallel to the uniform field and ΔU is the change in potential energy of the charge.
Ok. I also noticed that Vq = (J/C)(C), which is just Joules. I understand this by process of elimination. I wonder, did the problem imply a "uniform electric field" in this case? How would I know when the electric field is uniform or not?
A point charges produce a field that gets weaker as you move farther from the charge. So, the electric field is not uniform.
When you have two point charges, you can think of one of the charges as placed in the field of the other charge.
A uniform field is a special situation. It can be thought of as produced by a large flat plate of uniform charge density. Or,it can be produced by two large, flat parallel plates of opposite charge.
brake4country said:
Right. When I look at the units for B an C, I notice they are both in Nm = J. However, can you clarify when to use U = Eqd and U = Vq? My book states that Eqd is the potential energy or work done, which makes sense but I cannot see how they get U =Vq. Thank you.
Eqd can be visualised as the change in potential, asas TSny said above ΔU =- Eqd, because d isn't necessary the distance btw the charges whereas the potential directly depend on that distance r and if you have noticed Vq = E*q*r that all about it !
Oh I see. I have a similar problem which states the same scenario but the charged particle is moved "from a great distance". In this situation, it would be appropriate to use Eqd, right?
Edq is work, it's not allways a potential energy, doing work on a charge from a great distance give it enough kinetic energy to leave the field, E changes by the distance btw the charges, suppose that you're in a gravitation field, the work you do on a mass W = mgd isn't allways equal to the potential U = mgh,
Imagine that you lift the mass from a 10 meter roof a 5 m upward, this case W = 5mg whereas U = 15mg, that's the difference btw Eqd and Vq, V = E*r it's like gh, just focuse on these, Vq is the potential and Eqd is work, it may not be potential !
That is so very helpful! Thank you for your help!
If will help if you state the problem exactly as given.
well basically, voltage(potential difference) is equals to work done per unit charge. That means the amount of work done required to move a charge from one point to another point. That why it is called potential DIFFERENCE . To make things easier, there's an equation where V = W/Q.
So, if you want to find the potential energy of the charge. Use this formula to get the answer ^_^
Thank you. I will post this question in another thread.
Related to Electric charge and potential energy
1. What is electric charge?
Electric charge is a fundamental physical property of matter. It is a measure of the amount of electrical energy held by a particle or object. Electric charge can be positive or negative and is responsible for the electromagnetic force.
2. How is electric charge measured?
Electric charge is measured in units of coulombs (C). One coulomb is equal to the amount of charge transferred by a current of one ampere in one second. It can also be measured using a device called an electrometer.
3. What is potential energy in relation to electric charge?
Potential energy is the energy that a charged object possesses due to its position in an electric field. It is a measure of the work required to move a charge from one point to another in an electric field. The higher the potential energy, the greater the force exerted on the charge.
4. How does electric charge create an electric field?
Electric charge creates an electric field, which is a region of space around the charged object where other charged particles will experience a force. The strength of the electric field is determined by the amount of charge and the distance from the charged object.
5. Can potential energy be converted into other forms of energy?
Yes, potential energy can be converted into other forms of energy. When a charged object moves in an electric field, its potential energy is converted into kinetic energy. Additionally, potential energy can also be converted into thermal energy through the process of resistance in a circuit.
