Electric charge/Colombs law problems
  • Thread starter Thread starter RandellK02
    Electric Law
The discussion revolves around solving a problem involving electrostatic forces between three charged particles in an xy plane. The user is attempting to determine the coordinates for a third charge, q3, such that the net force on charge q2 is zero, given the values of q1 and q2. Initial calculations involve finding the forces between the charges using Coulomb's law, but the user is struggling to arrive at the correct coordinates for q3. An alternative approach suggests using the concept of the center of charge to simplify the problem, although it is noted that this method is unofficial and not recommended for exams. The user seeks clarification on their calculations and the correct method to find the solution.
RandellK02
I have a problem I am working on before the end of today and I am having some trouble getting the right answer. What am I missing?
1.
The charges and coordinates of two charged particles held fixed in an xy plane are q1 = 3.11 μC, x1 = 5.72 cm, y1 = 0.703 cm and q2 = -6.23 μC, x2 = -1.59 cm, y2 = 2.45 cm. At what (a)x and (b)y coordinates should a third particle of charge q3 = 5.06 μC be placed such that the net electrostatic force on particle 2 due to particles 1 and 3 is zero?
k=qQ/r^2
q1=3.1 E-6 x:0.0572 m y:0.00703 m
q2=-6.23 E-6 x:-0.0159 y:0.0245 m
q3=5.06 E-6
First I find F1,2 for the x component:
F1,2x=kq1q2/d2
note:d=-0.0159 - 0.0572
Next I conclude for equilibrium @q2 q1x=q3x. Same for y component.
So to find X of q3...
F1,3x ==> F1,2x= kq1q3/x2
I assumed solving for X will give me the answer but its incorrect...
Similar process for the y component.
A thing to say--There's a much shorter method for this.You know the center of mass of system is point where all forces due to mass is zero.Same we can apply here as center of charge(though this method works BUT IT IS NOT OFFICIAL.DON'T USE THIS IN YOUR EXAMS) with same formula as center of mass just by replacing mass by charge(m1 by q1).
9K
10K
