Electric dipole in a uniform electric field
In summary, an electric dipole in a uniform electric field experiences a torque that aligns it parallel to the field. This is due to two equal and opposite parallel forces, resulting in a net force of zero. When the net force is zero, the dipole moves parallel to the field.
logearav
338
An electric dipole placed in a uniform electric field experiences a torque which tends to align the dipole parallel to the field. At the same time, due to two equal and unlike parallel forces Eq and -Eq acting at q and -q, the net force is zero. When the net force is zero, how the dipole moves parallel to the field? Please help members.
hi logearav! :smile:
a torque (a couple) is a net force of zero :wink:
when the dipole is at an angle to the E field, the field pulls the opposite charges in opposite but parallel directions, and that turns the dipole :smile:
(and since the field is uniform, the forces are equal in magnitude, and the centre of mass stays where it is)
Mr. tiny-tim, thanks a lot for the explanation.
FAQ: Electric dipole in a uniform electric field
What is an electric dipole in a uniform electric field?
An electric dipole in a uniform electric field refers to two equal and opposite charges that are separated by a distance, resulting in a dipole moment. This dipole moment experiences a force when placed in a uniform electric field.
How is the dipole moment calculated?
The dipole moment is calculated by multiplying the magnitude of the charges by the distance between them. It is represented by the symbol "p" and its unit is Coulomb-meter (Cm).
What is the direction of the force on an electric dipole in a uniform electric field?
The force on an electric dipole in a uniform electric field is always directed from the positive charge to the negative charge. This direction can be determined using the right-hand rule, where the thumb points in the direction of the dipole moment and the fingers point in the direction of the electric field.
What happens to the electric dipole in a non-uniform electric field?
In a non-uniform electric field, the electric dipole experiences a torque in addition to a force. This torque causes the dipole to align itself with the direction of the electric field, with the positive charge facing towards the direction of the field.
What are the applications of electric dipoles in a uniform electric field?
Electric dipoles in a uniform electric field are used in various applications, such as in capacitors, sensors, and electric motors. They also play a crucial role in understanding the behavior of molecules in chemistry and biology.
