Electric dipole in electric field.
In summary, the question is asking for the amount of external work needed to turn an electric dipole moment, initially pointing in the direction of a uniform electric field, 90 degrees. The relevant equation is torque N = P x E, and the energy of a dipole in an electric field can be found using the equation E = k * P / r^3. To calculate the work, a force is needed, as in F * d.
dalarev
99
An electric dipole moment, vector P, is initially pointing in the directio of a uniform electric field, vector E (say, in the positive x direction). How much external work is needed to turn the dipole by 90 degrees?
vector P is directly proportional to E. It will tend to point in the same direction as E.
The only relevant equation I can gather is the torque N = p X E.
What's the energy of a dipole in an electric field? That equation should be right next to the equation you mention!
E of a dipole in an electric field = k * P/r^3
Wouldn't I need a force, as in F*d to find work?
Related to Electric dipole in electric field.
1. What is an electric dipole?
An electric dipole is a pair of equal and opposite charges separated by a small distance. It can also be thought of as a positive charge and a negative charge that are not located at the same point.
2. How does an electric dipole behave in an electric field?
An electric dipole experiences a torque (rotational force) when placed in an electric field. This torque causes the dipole to align itself with the direction of the electric field.
3. What is the electric dipole moment?
The electric dipole moment is a measure of the strength of an electric dipole. It is equal to the product of the magnitude of the charges and the distance between them.
4. How is the electric dipole moment calculated?
The electric dipole moment is calculated by multiplying the magnitude of one charge by the distance between the charges. It is also often represented by the letter "p" and has units of Coulomb-meters (C⋅m).
5. What are some real-life examples of electric dipoles?
Some examples of electric dipoles include water molecules (with the oxygen atom being slightly negative and the hydrogen atoms being slightly positive), magnets, and certain molecules with polar bonds such as carbon dioxide.
  • Classical Physics
