Electric Dipoles using Dirac's Delta function
In summary, the conversation pertains to a dipole consisting of two charges ±q at a distance d, and using Dirac's δ-function to write the charge density for this dipole. The charge (monopole moment), dipole moment, and quadrupole moments Q, p, and Qij are evaluated in the multipole expansion and it is shown that p agrees with the dipole moment. The conversation then shifts to a square arrangement of four charges in the xy plane, where the quadrupole moment is found and it is explained why the monopole and dipole moments vanish without calculation. The use of the electric dipole equation and the δ-distribution is mentioned as a hint for finding the higher order multipole
TheWire247
In the lectures, we considered a dipole, made of two charges ±q at a separation d. Using
Dirac's δ function, write the charge density for this dipole.
Evaluate the charge (monopole moment), dipole moment, and quadrupole moments Q, p,
and Qij in the multipole expansion for this case and show that p agrees with the dipole moment.
Now consider four charges, all in the xy plane, arranged in a square, centred at the origin
and edges parallel to the coordinate axes, all of magnitude q. Two charges, at opposite ends, are positive, the other two negative.
Find the quadrupole moment for this arrangement. Explain briefly, without calculation, why
the monopole and dipole moments vanish.
τ=PxE <=electric dipole equation
Many of us have been staring at this problem for hours with no success. Any help or pointers in the right direction would be very much appreciated
The charge distribution of a pure (mathematical) dipole in terms of the [itex]\delta[/itex]-distribution is given by
[itex]\rho_D(\mathbf r )=-\mathbf{p}\cdot\nabla\delta(\mathbf r - \mathbf r_D )[/itex] ,
which is not hard to show if you solve Gauss's law for the electrostatic potential - can you do that calculation? Hint: confirm your result here :)
Can you now find the higher order multipole moments if you express the given charge distributions in terms of sums over [itex]\delta[/itex]-distributions?
If you do not know how to do this, first think of a way to express a single charge using a [itex]\delta[/itex]-distribution.
Related to Electric Dipoles using Dirac's Delta function
1. What is an electric dipole?
An electric dipole is a pair of equal and opposite charges separated by a small distance. It is a fundamental concept in electromagnetism and is used to describe the behavior of electric fields and electric forces.
2. What is Dirac's Delta function?
Dirac's Delta function is a mathematical function that is used to represent a point-like source or sink of a particular quantity, such as mass or charge. It is often used in physics and engineering to model various phenomena, such as electric dipoles.
3. How is Dirac's Delta function used in electric dipoles?
Dirac's Delta function is used in electric dipoles to represent the point-like charges at the ends of the dipole. By using this function, we can simplify the mathematical expressions for electric fields and potentials, making it easier to analyze and understand the behavior of electric dipoles.
4. What are the key properties of electric dipoles?
The key properties of electric dipoles are their dipole moment, which is the product of the magnitude of the charges and the distance between them, and their orientation, which is the direction in which the dipole is aligned. These properties determine the strength and direction of the electric field produced by the dipole.
5. How are electric dipoles used in real-world applications?
Electric dipoles have many practical applications, such as in electronic devices, where they are used to create electric fields for various purposes, such as data storage and transmission. They are also used in materials science, where they play a crucial role in determining the properties of materials, such as their dielectric constant and polarizability.
