Electric field along the y-axis of a charged semicircle
In summary: Alright, thanks. Do you have any tips on how to solve the integral to get E_y?It can not be written in closed form, I am afraid. Writing up the potential is easier, but it also involves elliptic integral.
dumbperson
77
Find the electric field along the y-axis of a charged semicircle (with the center of the circle in the origin) with radius R, with a uniform charge distribution $$ \lambda$$ . https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcSzwZUlOz9K2R-JDyhgQrU0CSl08tKghH-4LTTamtYNjY-w7FNfPA
$$ \vec{E} = \frac{1}{4\pi \epsilon_0} \int \frac{dq}{|\vec{r}|^2} \hat{r} $$
$$ k = \frac{1}{4\pi \epsilon_0} $$
(r is the vector pointing from a charge dq to your ''test charge'' on the y-axis)
$$ dq= R\lambda d\theta $$
The positionvector of the charge dq $$ =\vec{r_1} = R \cos(\theta)\hat{x} + R \sin(\theta)\hat{y}$$
The positionvector of your ''test charge'' along the y-axis : $$\vec{r_2}=y\hat{y} $$
so the vector $$ \vec{r} = R \cos(\theta)\hat{x} + (R \sin(\theta)-y)\hat{y}$$
$$ |\vec{r}|= \sqrt{R^2\cos(\theta)^2+R^2\sin(\theta)^2+y^2-2yR\sin(\theta))}=\sqrt{R^2+y^2-2yR\sin(\theta)}$$
so $$\hat{r}= \frac{\vec{r}}{|\vec{r}|} = \frac{ R \cos(\theta)\hat{x} + (R \sin(\theta)-y)\hat{y}}{\sqrt{R^2+y^2-2yR\sin(\theta)}} $$
So the integral becomes
$$ \vec{E} = kR\lambda \int_0^\pi \frac{ R \cos(\theta)\hat{x} + (R \sin(\theta)-y)\hat{y}}{(R^2+y^2-2yR\sin(\theta))^{\frac{3}{2}}} d\theta $$
So $$ E_x = kR^2\lambda \int_0^\pi \frac{\cos(\theta)}{(R^2+y^2-2yR\sin(\theta))^{\frac{3}{2}}} d\theta$$
$$ E_y = kR\lambda \int_0^\pi \frac{R\sin(\theta)-y}{(R^2+y^2-2yR\sin(\theta))^{\frac{3}{2}}} d\theta $$
Am I doing this correctly? I managed to solve the integral for E_x and the result is zero, as expected. But I have no clue how to solve E_y, is this integral set up correctly? Well I could solve it for y=0 pretty easily, but that is not the assignment.
Thanks
Check the sign of the electric field. Otherwise it looks correct.
ehild
ehild
ehild
for providing your solution attempt. It appears that you have set up the integral correctly for E_y, but the integration may be challenging to solve analytically. If you are unable to solve it, you may want to consider using numerical methods to approximate the value of E_y. Additionally, you could also check your work by using a computer program or simulation to calculate the electric field at different points along the y-axis and compare it to your analytical result.
FAQ: Electric field along the y-axis of a charged semicircle
What is an electric field?
An electric field is a physical field that surrounds a charged particle and exerts a force on other charged particles in its vicinity.
How is the electric field along the y-axis of a charged semicircle calculated?
The electric field along the y-axis of a charged semicircle can be calculated using the formula E = k*q*y/(r^2+y^2)^(3/2), where k is the Coulomb's constant, q is the charge of the semicircle, y is the distance along the y-axis, and r is the radius of the semicircle.
What factors influence the electric field along the y-axis of a charged semicircle?
The electric field along the y-axis of a charged semicircle is influenced by the magnitude and sign of the charge of the semicircle, as well as the distance from the semicircle along the y-axis.
How does the electric field change as the distance from the semicircle increases?
The electric field decreases as the distance from the semicircle increases. This is due to the inverse square relationship between the electric field and the distance from the charged object.
Can the electric field along the y-axis of a charged semicircle be negative?
Yes, the electric field along the y-axis of a charged semicircle can be negative if the charge on the semicircle is negative. This indicates that the electric field is pointing in the opposite direction of the y-axis.
