Electric field and ball of charge
In summary, a ball with a mass of 0.180 g and positive charge of q=31.0 mC is suspended in a uniform electric field, hanging at an angle of q=16.0o from the vertical. To find the magnitude of the electric field, the free body diagram was drawn and forces in the x and y directions were calculated. The equation E=Tsine(16)+q was used, but it was later corrected to Eq=Tsin(16).
Rasine
208
As shown in the figure above, a ball with a mass of 0.180 g and positive charge of q=31.0
mC is suspended on a string of negligible mass in a uniform electric field. We observe
that the ball hangs at an angle of q=16.0o from the vertical. What is the magnitude of
the electric field?
so i drew a free body diagram and now i am going to calcuate the forces in the x and y
directions to see what E is.
since the ball is stationary Fx=0=E-Tsin(16)+q
so E=Tsine(16)+q
now i solve for T by finding the forces acting in the y direction Fy=0=Tcos(16)-mg
so T=mg/cos(16)...so i substitute that into Fx and now E=(mg/cos(16))sin(16)+q
what am i doing wrong?
Good.
so E=Tsine(16)+q
The force exerted by the (presumably horizontal) electric field on the charge is Eq. Rework this part.
What's with the '+q' term?
so it would be E=Tsin(16)+Eq?
No. It would be Tsin(16)-Eq = 0.
Not quite. Just redo your calculation of Fx.
Fx=0=E-Tsin(16)+the charge of the particle
where is the Electric field coming into play agian...i don't understand
This makes no sense. You are adding the horizontal forces on the charged object. What forces act on it? E is the field, not the force! q is the charge, also not a force.
Reread the posts by neutrino and myself.
so the force due to the electric field is F=Eq so instead of E=Tsine(16) i would have Eq=Tsin(16)??
Yes. Now you've got it.
thank you so much. i really appreciate it.
FAQ: Electric field and ball of charge
What is an electric field?
An electric field is a force field that surrounds an electrically charged object or group of objects. It is created by the presence of electric charges and can exert a force on other electrically charged objects within its range.
How is an electric field measured?
The strength of an electric field is measured in units of newtons per coulomb (N/C). This measures the amount of force that would be exerted on a one-coulomb charge placed within the field.
What is a ball of charge?
A ball of charge is a hypothetical object that has a uniform distribution of electric charge. This means that the charge is evenly spread out throughout the entire object, resulting in a spherical shape.
How does the electric field affect a ball of charge?
The electric field exerts a force on the ball of charge, causing it to experience a net force and move in the direction of the field. The strength of the force depends on the charge of the ball and the strength of the electric field.
Can a ball of charge have a negative charge?
Yes, a ball of charge can have a negative charge. This means that the electric field surrounding the ball would point inward, towards the center of the ball, instead of outward like a positively charged ball. The strength of the field would still depend on the magnitude of the charge.
