Electric field and boundary conditions
In summary, the problem involves a spherical capacitor filled with two different dielectric materials and with charges on the outer and inner surfaces. By using the boundary conditions and Gauss's law, the electric field is found to be radially dependent in the sphere with a specific vector form.
KFC
488
One half of the region between the plates of a spherical capacitor of inner and outer radii a and b is filled with a linear isotropic dielectric of permittivity [tex]\epsilon_1[/tex] and the other half has permittivity [tex]\epsilon_2[/tex], as shown in the figure. If the inner plate has total charge +Q and the outer plate has total charge -Q, find the field everywhere in the sphere
http://img78.imageshack.us/img78/4120/bndal8.gif
2. The attempt at a solution
Well, this is an old problem and I know the solution of this problem. But it is quite confusing about the boundary condition and the form of the field.
1) Since all charges are located on outer and inner spherical surface, so there is no net charged found in the contact surface, which is illustrated with the normal direction in the figure. According to the boundary condition, we have
[tex]D_{2n} - D_{1n} = Q_{inc} = 0[/tex]
and the electric field along the tangential direction always be continuous, that is
[tex]E_{2t} \equiv E_{1t}[/tex]
I wonder what about the tangential direction of the displacement field? Are they continuous in general?
2) The solution manual tells that according to the boundary, it takes the form of the electric field as of radial-dependent
[tex]\vec{E} = \frac{A\vec{r}}{r^3}[/tex]
I am really confuse about this: how can you tell the field is of this form by boundary condition? or how can you prove the field in this form satisfies all boundary conditions?
Due to the boundary conditions, the electric field will be radially the same in the sphere, hence due to Gausses law we have:
[tex]\epsilon_0\epsilon_1 E 2r^2\pi + \epsilon_0\epsilon_2 E 2r^2\pi =Q [/tex]
So from here we obtain:
[tex]E=\dfrac{Q}{2\pi\epsilon_0(\epsilon_1+\epsilon_2)}\dfrac{1}{r^2} [/tex]
In vector form (since there is only a radial component of the electric field):
[tex]\vec{E}=\dfrac{Q}{2\pi\epsilon_0(\epsilon_1+\epsilon_2)}\dfrac{\vec{r}}{r^3}[/tex]
I hope its clearer noe
FAQ: Electric field and boundary conditions
What is an electric field?
An electric field is a physical field that is created by electrically charged objects. It is a vector field, meaning it has both magnitude and direction, and it exerts a force on other charged particles within its influence.
How is an electric field calculated?
The strength of an electric field is calculated by dividing the force exerted on a test charge placed within the field by the magnitude of the test charge. This results in a unit of measurement called Newtons per Coulomb (N/C).
What are the boundary conditions for an electric field?
The boundary conditions for an electric field refer to the rules that govern how the electric field behaves at the interface between different materials or regions. These include the continuity of the electric field, the continuity of the electric displacement, and the continuity of the normal component of the electric flux density.
Can an electric field exist in a vacuum?
Yes, an electric field can exist in a vacuum. In fact, electromagnetic waves, including visible light, are examples of electric fields propagating through a vacuum. In a vacuum, the electric field is typically referred to as the permittivity of free space and is denoted by the symbol ε0.
What are the applications of electric fields?
Electric fields have a wide range of applications in everyday life, such as powering electronic devices, generating electricity, and controlling the movement of charged particles in medical procedures. They also play a crucial role in technologies like telecommunication, radar, and microwave ovens.
