Electric field at the point within the sheet
In summary, a nonconducting sheet with a thickness of 10 cm and surface charge densities of +95 nC/m^2 and -25.0 nC/m^2 on the upper and lower faces, respectively, has an electric field of 2172656.25 N/C at a point 2.00 cm below the upper face. This can be calculated using the formula σ/2ε, where σ is the surface charge density and ε is the permittivity of free space. The correct formula for E in this case is not E= k q/r^2, as that is for point charges.
cupcake
76
A huge (effectively infinite) horizontal nonconducting (epsilon = epsilon_0) sheet 10 cm thick has charge over both faces. The upper face carries a uniform +95 nC/m^2 while the lower face carries a uniform -25.0 nC/m^2. The magnitude of the electric field at a point within the sheet 2.00 cm below the upper face is closest to :
E= k q/r^2
Etotal = E1 + E2
E1 = k q1 / r^2 = 9 * 10^9 * 95 *10^-9 / (0.02)^2 = 2137500
E2 = k q2 / r^2 = 9 * 10^9 * 25 *10^-9 / (0.08)^2 = 35156.25
Etotal = E1+E2 = 2172656.25 N/C
is this correct or not?
Thanks
Your formula for E is for point charges. For an infinite sheet of charge with surface charge density σ, E is σ/2ε. You can prove this using Gauss' law.
for your question. Your approach is correct. The electric field at a point within the sheet can be calculated by taking the sum of the electric fields due to the charges on both faces of the sheet. However, there is a small error in your calculation for E2. The distance between the point and the lower face of the sheet is 0.08 m, not 0.02 m. So the correct value for E2 would be:
E2 = k q2 / r^2 = 9 * 10^9 * 25 *10^-9 / (0.08)^2 = 625000 N/C
Therefore, the correct value for Etotal would be:
Etotal = E1 + E2 = 2137500 + 625000 = 2762500 N/C
This is the closest value to the magnitude of the electric field at the point within the sheet. Keep up the good work!
FAQ: Electric field at the point within the sheet
What is an electric field at a point within a sheet?
An electric field at a point within a sheet is a measure of the force that a positive test charge would experience at that point if placed within the sheet. It is a vector quantity, meaning it has both magnitude and direction.
How is the electric field at a point within a sheet calculated?
The electric field at a point within a sheet can be calculated using the formula E = σ/2ε, where σ is the surface charge density of the sheet and ε is the permittivity of the material the sheet is made of.
What factors affect the electric field at a point within a sheet?
The electric field at a point within a sheet is affected by the surface charge density of the sheet, the distance between the point and the sheet, and the permittivity of the material the sheet is made of. It is also affected by the presence of other nearby charges.
How does the direction of the electric field at a point within a sheet affect the motion of a charged particle?
The direction of the electric field at a point within a sheet determines the direction of the force that a charged particle would experience if placed at that point. This force can either attract or repel the particle, causing it to move in a specific direction.
Is the electric field at a point within a sheet the same at all points?
No, the electric field at a point within a sheet can vary depending on the location of the point and the distribution of charges on the sheet. In general, the electric field is stronger closer to the sheet and weaker further away.
