Electric field between parallel plates
The discussion focuses on the electric field between parallel plates of a capacitor, emphasizing that each plate carries opposite charges, with one plate having a surface charge density of σ and the other -σ. It raises questions about the nature of charge distribution on the plates and the presence of negative charges in a static electric field scenario. The electric field outside a single conducting plate is described by the equation E = σ/ε, while the field between two plates is derived using the superposition principle. The conversation highlights a fundamental misunderstanding regarding the application of these principles to capacitors. Overall, the interaction of electric fields in capacitors is crucial for understanding their behavior in static situations.
lys04
The electric field outside a conducting plate of charge is given by sigma/epsilon right? Then why not for a capacitor, since that is 2 conducting plates, is the electric field 2sigma/epsilon using superposition principle?
E=sigma/epsilon
Here’s a cross -section through (due to space limitations, part of) an infinite conducting plate with a (say) positive charge:
___________________________
Here are some questions to consider:
- are both surfaces charged?
- if only one (of the two) surfaces is charged, what determines which one?
- in a static situation, every ‘field line’ starts on a positive charge and ends on a negative charge; where are the negative charges here?
lys04 said:
Homework Statement: The electric field outside a conducting plate of charge is given by sigma/epsilon right? Then why not for a capacitor, since that is 2 conducting plates, is the electric field 2sigma/epsilon using superposition principle?
Relevant Equations: E=sigma/epsilon
Generally, the two plates of a capacitor are oppositely charged. Right?
So, if one plate has a surface charge density, ##\sigma##, then the other plate has surface charge density, ##-
\sigma##,
Now use superposition to determine the electric field outside the plates as well as between the plates.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
