Electric field between point and infinite plate
In summary, the question posed is about the difference between two scenarios involving a point charge and an infinite plate with thickness comparable to the distance between them. The first scenario involves placing the infinite plate at ground and applying a voltage on the point charge, while the second scenario involves placing the point charge at ground and applying a voltage from the infinite plate. The expert responds that, in terms of voltage and potential difference, there is no significant difference between the two scenarios. However, the caveat is that the plate must be conductive for this to hold true. It is also pointed out that making the point charge "ground" may introduce singular potentials in inconvenient locations.
Erikve
Dear all,
I think I have an easy problem for you, however I get confused by the simplicity and complexity at the same time.
Situation is like this: I have a point charge at a distance d from an infinite plate with thickness comparable to the distance d. Is there difference between the electric field op these scenarios:
1. I put the infinite plate at ground and apply a voltage on the point charge
2. I put the point charge at ground and apply a voltage from the infinite plate
Naively my response: there is not difference. But when I thought about the distribution of charge carriers in both scenarios... the ground makes it complicated where charge is in both situations.
You're always interested in the voltage/potential difference. In this case you seem to just be swapping the ground reference which can leave the voltage differences the same. The caveat being that the plate is conductive, thus making it an equipotential surface (otherwise one may argue that locally enforcing a potential on the plate does not make the entire plate the same potential).
Though I would point out that it does not make sense for you to make the point charge "ground." You still need to obey the basics of electrostatics which follows Poisson's equation. That is, the Laplacian of the potential is proportional to the charge density. But for a point charge, the potential field that satisfies this relationship is singular at the charge's location (Coulomb's Law). So if you took the position of the point charge as your ground reference then you would probably be introducing various singular potentials in inconvenient spots.
FAQ: Electric field between point and infinite plate
What is an electric field between a point and an infinite plate?
The electric field between a point and an infinite plate is a force field that exists between a single point and an infinitely large conducting plate. It is created by the accumulation of charges on the surface of the plate and can be either positive or negative.
How is the electric field between a point and an infinite plate calculated?
The electric field between a point and an infinite plate can be calculated using the formula E = σ/2ε0, where σ is the surface charge density of the plate and ε0 is the permittivity of free space. This formula applies to a point located at any distance from the plate.
What is the direction of the electric field between a point and an infinite plate?
The direction of the electric field between a point and an infinite plate is perpendicular to the surface of the plate and points away from the plate for a positive charge and towards the plate for a negative charge. This is known as the normal direction.
How does the distance from the point to the plate affect the electric field?
The electric field between a point and an infinite plate is inversely proportional to the distance between the point and the plate. This means that as the distance increases, the electric field strength decreases. However, for an infinitely large plate, the electric field is considered constant at any distance.
What are some real-life applications of the electric field between a point and an infinite plate?
The electric field between a point and an infinite plate has various applications in electronic devices, such as capacitors and touchscreens. It is also used in electrostatic precipitators, which remove particles from industrial exhaust gases. Additionally, the concept of an infinite plate is often used in theoretical models to simplify calculations and understand the behavior of electric fields.
