rbsann
- 3
Member advised to use the homework template for posts in the homework sections of PF.
Hello all, i am having a hard time with EM, specially with the most simple concepts that i don't seem to grasp at all and the simple exercises that should be quite simple to solve.
So the question is. ( i will omit the constant (1/4pieo) for practice sake
When i calculate the eletric field, first i determine the r (distance vector) just like i learned in this instructional video (). The example given is to calculate the electric field on the y-axis due to two point charges on the x axis, with opposite signs.
Then i do: E1= q(-xi+yj) / ((x2+y2))3/2
E2=-q(xi+yj) /((x2+y2))3/2
That works just fine and i get the resultant E from the vector sum of each E. But that method is not working when i have to calculate the eletric field on the x axis.
In this exercise, that is giving me trouble. i have to determine E in a x point between a and -a ( positions of q and -x) respectively. I can see, quite easily, that the resultant vector should be pointing to -i axis, but i can't get at the teacher answer. My attempt at solving:
E1=q*(x-a)i/(x-a)3
E2=-q(x+a)i/(x+a)3
Summing those two give a different result, that should be: -2q*(x2+a2) divided by ((x-a))4
Where exactly is my mistake?
Thanks in advance
E1=q*(x-a)i/(x-a)3
E2=-q(x+a)i/(x+a)3
Thanks in advance
