Electric Field/Centripital Force/Gauss law question?
In summary, to find the charge in coulombs on a charged sphere, we can use the equation (k*q1*q2)/r^2 = F = mv^2/r, where k is the Coulomb constant, q1 is the charge of the proton, q2 is the unknown charge on the sphere, r is the radius of the sphere, m is the mass of the proton, and v is its speed. By rearranging the equation and substituting the given values, we can find the charge on the sphere to be negative, indicating that the Coulomb force is responsible for the proton's centripetal acceleration.
momatik
A proton with speed v = 3.42 x 106 m/s orbits just outside a charged sphere of radius r = 0.862 cm. What is the charge in coulombs on the sphere?
(k*q1*q2)/r^2
F = mv^2/r
Gauss Law for sphere, possibly? I'm not sure if I need this.
setting the equations equal to each other and then solving for q2
kq1q2/r2 = mv^2/r
rearranged...
q2= mv^2r/kq1
m = mass of proton = 1.672e-27
q1 = charge of proton = 1.602e-19
v = 3.42e6
r = .00862 m
Values subbed in...
q2 = [(1.672e-27)*(3.42e6^2)*(.00862)] / [(9e9)*(1.602e-19)]I get 1.1696e-7 which is incorrect.
I haven't checked your numbers, but you seem to be forgetting that force is a vector, not a scalar. You need to consider the direction of both the centripetal and Coulomb forces...what sign must q2 be for the Coulomb force to be responsible for the centripetal acceleration of the proton?
Wow Yeah, the answer simply had to be negative. I justifiably feel pretty stupid right now.
Thanks for your help.
FAQ: Electric Field/Centripital Force/Gauss law question?
What is an electric field?
An electric field is a physical quantity that represents the force exerted on a charged particle by other charged particles in its vicinity. It is a vector quantity, meaning it has both magnitude and direction, and is typically measured in units of Newtons per Coulomb (N/C).
How is centripetal force related to electric fields?
Centripetal force is the inward force that keeps an object moving in a circular path. In the context of electric fields, centripetal force is the force that keeps a charged particle moving in a circular path around a central charged object. This force is generated by the electric field of the central charged object.
What is Gauss's law?
Gauss's law is a fundamental law in electromagnetism that relates the electric field at a point to the charge enclosed by a surface surrounding that point. It states that the electric flux through any closed surface is equal to the total charge enclosed by that surface divided by the permittivity of free space.
How is Gauss's law used to calculate the electric field?
Gauss's law can be used to calculate the electric field at a point by first choosing a closed surface that encloses the point of interest. Then, the electric flux through that surface can be calculated using the enclosed charge and the permittivity of free space. Finally, the electric field at the point of interest is equal to the electric flux divided by the surface area of the chosen closed surface.
Can Gauss's law be applied to any charge distribution?
Yes, Gauss's law can be applied to any charge distribution, as long as the charge enclosed by the chosen surface can be determined. However, the calculations may become more complex for non-uniform charge distributions, and other methods such as integration may be necessary.
