B Electric Field Created by 2 Infinite Plates
The discussion focuses on the electric field generated by two infinite parallel plates using Gauss's law. The electric field from a single plate is given by E = σ/(2ε₀), and when considering two plates, the fields between them cancel each other out, resulting in a net electric field of zero. Outside the plates, the fields add constructively, leading to a total electric field of E = σ/ε₀. The principle of superposition applies, as electric fields from different sources combine due to the linearity of Maxwell's equations. This approach effectively demonstrates the behavior of electric fields in the presence of multiple charged plates.
Heisenberg7
Today, I watched a video about electric field created by an infinite plate by Khan Academy. They were talking about the clever application of the Gauss's law in this case (the cylinder method), so I wondered if I could apply the same thing but to 2 plates. For example, let's say that the plates are parallel. In this case the electric field created by one plate is ##E = \frac {\sigma}{2\epsilon_o}##. Since electric field is a vector quantity we can vectorially add up the electric field created by both plates. Between the plates the electric field created by one plate is opposite and equal to the electric field created by the other, thus if we vectorially add them up, we get 0. But on the left and right side, it's different. They have the same direction and magnitude at each point in space, thus the electric field at any point is ##E = \frac {\sigma}{\epsilon_o}##. Is this the correct way to think about this problem? (both plates have the same charge ##q##)
Yes, electric fields generated from different sources add up to a superposition of the individual contributions. However, note that this is a result of the linearity of the governing differential equation, ie Gauss’ law or ultimately Maxwell’s equations. It does not follow solely from being a vector field.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
