B Electric Field Created by a Finite Plate
The discussion revolves around calculating the electric field created by a finite plate at a specific point in a Cartesian coordinate system. It questions the applicability of Gauss's law for this scenario, noting that only the z-components of the electric field contribute due to symmetry, as the x and y components cancel out. A cylindrical Gaussian surface is proposed for the calculation, despite the lack of symmetry. Advanced calculus is referenced, leading to a specific equation for the electric field at the point in question. The conversation highlights the complexities involved in applying Gauss's law to non-uniform charge distributions.
Heisenberg7
Let's assume that we have a finite plate which is at the center of a cartesian coordinate system. Now let's define a point ##r## with coordinates ##(0, 0, z)##. My question is, can we use Gauss's law to find the electric field at this point? The direction of the electric field is going to be up so all the ##x## and ##y## components will cancel out leaving us with only ##z## components of all the electric fields created by the infinitesimal points on the plane. Now, would it be possible for us to create a gaussian surface like a cylinder and calculate the electric field at the point ##r##?
I've seen a video about this and the guy explaining it uses some pretty advanced calculus to find the electric field at the point r. In the end, he gets this equation: $$\vec{E}(\vec{r}) = \frac {Q}{4\pi\epsilon_oab} \arctan(\frac {ab}{2z \sqrt{a^2+b^2+4z^2}})$$
I guess this is a dumb question because there is basically little to no symmetry (only along the z axis is the electric field pointed upwards).
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
