Electric field Difference between Electrostatics and Electrodynamics
In summary, in electrostatics, electric fields are time-independent but position-dependent. They are always zero inside a charged or uncharged conductor, but nonzero and perpendicular to the surface at the conductor's surface. In electrodynamics, E and B fields are always present together and electric field lines never cross. In a perfect conductor, no net electric field is possible inside, but two equal and opposite E fields can exist due to an emf generated by motion in a magnetic field.
fog37
1,568
108
Hello everyone,
I have been pondering on the behavior of the E field in conductors.
In electrostatics (where the charges are not moving):
a) Electric fields are time- independent but position-dependent
b) Electric fields are always zero inside a charged or uncharged conductor. At the conductor surface, the E field is nonzero and perpendicular to the surface itself. For example, a neutral conductor immersed inside a static E field will have zero internal E field, induced surface charged and nonzero, perpendicular E field at the surface
(interestingly, a static magnetic field ##B## can penetrate inside a conductor, so we cannot shield the conductor's interior from it).
What about in electrodynamics where charges are moving, charge densities are time-varying, and the electric field ##E(r,t)## depends on time?
For example, does a conductor immersed inside a time varying E field still have a zero internal E field?
Are there situations, in electrodynamics, in which a conductor has a nonzero internal E field?
In electrodynamics, both E and B fields are always present together...
Thank you!
I would add that electric field lines never cross in electrostatics and electrodynamics.
In electrostatics, E field lines start on positive charges and end on negative charges...I think it is true also in electrodynamics where E field lines can also form closed loops that do not start/end on any charge
If it's a perfect conductor, no net electric field is possible inside it, not even if there is current flowing in it.
However, even in a perfect conductor there can exist two equal and opposite E fields. This can happen when an emf is generated. For example, in a perfect conductor of length L moving with velocity v perpendicular to a constant B field there is emf generated = BLv. vB constitutes effectively an E field. This becomes obvious if you imagine yourself sitting on the moving conductor; to you there is no v so no Lorentz force. The only possibility is an E field = v x B. To counteract the vB field an electrostatic field comprising free charge concentrated near both ends of the conductor is also generated in the opposite direction. Equilibrium is reached when the magnitudes of the two fields are equal.
Related to Electric field Difference between Electrostatics and Electrodynamics
1. What is the main difference between electrostatics and electrodynamics?
The main difference between electrostatics and electrodynamics is that electrostatics deals with stationary or constant electric fields, while electrodynamics deals with changing or time-varying electric fields.
2. How is the electric field calculated in electrostatics?
In electrostatics, the electric field is calculated using Coulomb's law, which states that the electric field strength at a point is directly proportional to the magnitude of the charge and inversely proportional to the square of the distance between the charges.
3. How does the electric field change in electrodynamics?
In electrodynamics, the electric field can change due to the motion of charges or the presence of changing magnetic fields. This can result in the generation of electromagnetic waves.
4. Can the electric field exist without charges in electrodynamics?
Yes, in electrodynamics, the electric field can exist without charges. This is because changing magnetic fields can create electric fields, even in the absence of charges.
5. What is the significance of the electric field in electrodynamics?
The electric field plays a crucial role in electrodynamics as it is one of the fundamental components of electromagnetic waves. These waves have a wide range of applications, including communication, radar, and medical imaging.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
