Electric field due to a Solid Non-Conducting Sphere
In summary: Thus, the field due to the charged shell is the same as if all of the charge was concentrated at the center of the sphere.
Siddharth Barua
"Find the electric field due to a solid conducting sphere of uniform charge distribution using Coulomb's law and brute force integration only. Use Gauss' Law to verify the result.
Coulomb's law for element field dE[/B]
I integrated the resulting function. I used spherical polar coordinates and have obtained dq, rho and dv
All the charge will be distributed on the surface of the conductor. So no charge will be inside.
The field outside will look like the source is a point charge. The field inside will be zero.
Please read the question carefully. It says "solid" sphere
So the charge is uniformly distributed throughout the *solid*, instead of the surface? That's not what occurs in conductors, generally. Usually that's with charged insulators.
In either case, then you use Gauss' theorem to show that E increases linearly with radius inside the sphere, and then behaves like a point charge field outside the sphere.
Inside E ~ r
Outside E ~ 1/r^2
Okay, that's an error on my part. It is definitely a non conducting solid sphere as it has a uniform charge distribution. But my friend @DuckAmuck the parameters of the question clearly states that I need to use the ONLY coulomb's law and Integrate that to deduce the expression. Thanks anyways.
I need to integrate this
∫dE= k ∫ ρ{(S^2 dS sinθdθdφ(r-Scosθ)}/((S^2 + r^2 - 2rScosθ)^3/2)
how do i go about it?
You can start by finding the electric field due to a thin disk of radius, a, and uniform charge density, ρ, at a distance of u along the axis of the disk.
Let u=Cosθ
You can use Coulomb's law! You don't even need to do an integral.:smile:
Let's say the sphere has radius R, and total charge Q.
So if you're outside the sphere (r>R), it's easy, the field is like a point charge: [tex]E_{out} = \frac{kQ}{r^2}[/tex]
If you are inside the sphere (r<R), it's different. The amount of charge you encounter is reduced, since your Gaussian surface doesn't enclose the entire sphere: [tex] Q' = \frac{r^3 Q}{R^3}[/tex]
So now, just plug and chug: [tex]E_{in} = \frac{kQ'}{r^2}[/tex]
[tex] E_{in} = \frac{k}{r^2} \frac{r^3 Q}{R^3}[/tex]
[tex] E_{in} = \frac{kQr}{R^3}[/tex]
I looks like this fact is precisely what OP is to show by doing the full blown integration.
Likes haruspex
Coulomb's Law does not say it is like a point charge. To apply Coulomb's Law you would first have to show it is like a point charge, but the constraints specified in the problem forbid the easy ways of knowing that. Instead, it explicitly requires Siddharth to solve the integral.
Posts #7 and #8 look appropriate, and probably equivalent.
Likes SammyS
If you can show that the field due to a spherical shell at a point outside the shell is the same as if
all of the charge where concentrated at the center of the shell, then since a solid sphere is composed
of an infinite number of such shells; then for a uniformly charged sphere the field outside the
sphere must be the same as that as for a single charge at the center of the sphere.
What's your point?
Likes haruspex
I posted this because I don't know the difficulty of integrating the field due to charged disks.
Finding the field due to a charged shell is tricky but not difficult.
R = radius of charged sphere
r = radius of sphere centered at point P, the point outside of the charged sphere.
Consider the intersection of the two spheres.
L = distance between centers
A = angle to intersection of spheres (along line of centers) for sphere R
B = angle to intersection of spheres for sphere r
Width of strip on R = R dA
Area of strip = 2 pi R^2 sin A dA
dQ = o 2 pi R^2 sin A dA where o is the charge density of the strip
dE = K dQ cos B / L^2 since components of field perpendicular to L cancel
Now you need to use the Law of Cosines to eliminate some variables and get an integral in r only
r^2 = R^2 + L^2 - 2 R L cos A
2 r dr = 2 R L sin A getting rid of the sine
Also, cos B = (r^2 + L^2 - R^2) / (2 R L) getting rid of the cosine
Now the equation is integrable in r from L - R to L + R
And the charge on the spherical shell is Q = 4 pi o R^2
You should get E = K Q / L^2
Related to Electric field due to a Solid Non-Conducting Sphere
What is an electric field?
An electric field is a physical quantity that describes the influence of electric forces on a charged particle. It is a vector quantity, meaning it has both magnitude and direction.
What is a solid non-conducting sphere?
A solid non-conducting sphere is a spherical object made of a material that does not allow the flow of electric current. Examples include plastic, wood, and glass.
How is the electric field due to a solid non-conducting sphere calculated?
The electric field due to a solid non-conducting sphere can be calculated using Coulomb's Law, which states that the electric field at any point outside the sphere is directly proportional to the charge of the sphere and inversely proportional to the square of the distance from the center of the sphere.
What factors affect the electric field due to a solid non-conducting sphere?
The electric field due to a solid non-conducting sphere is affected by the charge of the sphere, the distance from the center of the sphere, and the dielectric constant of the surrounding medium.
How does the electric field due to a solid non-conducting sphere differ from that of a solid conducting sphere?
The electric field due to a solid non-conducting sphere is only present outside the sphere, while the electric field due to a solid conducting sphere is present both inside and outside the sphere. Additionally, the electric field inside a solid non-conducting sphere is zero, while the electric field inside a solid conducting sphere is non-zero.
