Electric Field in a cylindrical Coaxial Capacitor
In summary, two infinite coaxial metal cylindrical tubes with radii a and b (a < b) are charged with charge per unit length \lambda and -\lambda respectively. The electric field between the tubes (a < r < b) can be calculated using Gauss' law and a Gaussian surface with radius R and length L. The electric field is constant along the Gaussian surface and its direction points from positive to negative charges.
redz
Two infinite coaxial metal cylindrical tubes of radius a and b (a < b) are charged
with charge per unit length (unit [C/m]) [tex]\lambda[/tex] and [tex]-\lambda[/tex] respectively.
Calculate the electric field between the tubes (i.e. for a < r < b)
Where [tex]\epsilon_{0}[/tex] is the permittivity of free space
2. The attempt at a solution
Considering a Gaussian surface with radius R & length L where a < R < b, we can use Gauss' law to find the enclosed charge;
[tex]\oint \vec{E}. d\vec{a} = \frac{ q_{enc}}{\epsilon_{0}}[/tex]
This can then be rewritten as;
[tex]\oint \vec{E}. d\vec{a} = \frac{\lambda L}{\epsilon_{0}}[/tex]
Then I have no clue of where to go. Can take the magnitudes of the vectors and take the E outside or do i have to do something different?
Well you defined a Gaussian surface (a cylinder with radius R). Since it has the same symmetry as the charges, you can claim that the electric field will be constant along your Gaussian surface. That way you can pull it out of the integral, and you will be left with E*A, where A is the area of your Gaussian surface.
The direction of the electric field will point from positive to negative charges.
That makes perfect sense thank you very much.
Related to Electric Field in a cylindrical Coaxial Capacitor
1. What is an electric field in a cylindrical coaxial capacitor?
An electric field in a cylindrical coaxial capacitor refers to the distribution of electric charge within the capacitor, which is composed of two cylindrical conductors separated by an insulating material. The electric field is strongest between the two conductors and decreases as distance from the conductors increases.
2. How is the electric field calculated in a cylindrical coaxial capacitor?
The electric field in a cylindrical coaxial capacitor can be calculated using the formula E = V/d, where E is the electric field strength, V is the voltage between the two conductors, and d is the distance between the conductors. This formula assumes that the electric field is uniform between the conductors.
3. What factors affect the electric field in a cylindrical coaxial capacitor?
The strength of the electric field in a cylindrical coaxial capacitor is affected by several factors, including the distance between the conductors, the voltage applied to the capacitor, and the dielectric material between the conductors. The shape and size of the conductors can also impact the electric field.
4. How does the electric field in a cylindrical coaxial capacitor differ from other capacitor designs?
The electric field in a cylindrical coaxial capacitor is unique because of its cylindrical shape. Unlike other capacitor designs, the electric field is strongest in between the two conductors, rather than on the surface of the conductors. This design allows for a higher capacitance and more efficient energy storage.
5. What are the practical applications of a cylindrical coaxial capacitor?
Cylindrical coaxial capacitors have many practical applications, including in electronic circuits, power transmission systems, and high voltage equipment. They are also commonly used in radio frequency transmission and reception, as well as in medical devices such as MRI machines. Additionally, cylindrical coaxial capacitors are used in particle accelerators and other scientific research equipment.
