Electric field in a cylindrical conductor
In summary, according to the solutions, the electric field is zero everywhere due to magnetostatics and the net charge is zero everywhere. However, the electric field given by Ohm's law is not zero, and it converges to zero as the conductor is defined to be "very long."
Nikitin
735
27
Problem 1c from here: http://web.phys.ntnu.no/~ingves/Teaching/TFY4240/Exam/Exam_tfy4240_Dec_2013.pdf
Maxwell's equations
According to the solutions, the electric field is ZERO everywhere because it's "magnetostatics" and because the net charge is zero everywhere. http://web.phys.ntnu.no/~ingves/Teaching/TFY4240/Exam/Solution_tfy4240_Dec_2013.pdf
But, in that case, what about the electric field (given by Ohm's law) which is driving the current in the first place? That one is certainly not zero. Or does it "converge to zero" since the conductor is defined to be "very long" and ohm's law gives ##\lim_{|d| \to \infty} IR = \vec{E} \cdot \vec{d} ##
Maxwell's equations
Isn't the question asking for the radial electric field (i.e. the E-field in the x-y plane), the field driving the current would be along the wire not radially.
No it's asking for the Electric field ##\vec{E}(\vec{r})=\vec{E}(\vec{r_{||}})##, i.e. E as a function of radial r.
Part b asks for the magnetic field as a function of distance from the z-axis, where the current flows parallel to z. It then asks you to repeat the process for the electric field, which would imply it is the electric field perpendicular to the current.
In the solutions to part b, the magnetic field is given as a function of the radial component only, the question is similarly explained in the footnote at the bottom of the question page, where it states 'Obtain the electric field E(r) as a function of r||=|r|||' for the same regions.
Likes Nikitin
they asked for the magnetic field as a function of radial distance. i don't think they said anything about finding the magnetic field-component perpendicular to the current.
Regardless, wouldn't the electrical field inside a conducting wire like this approach zero anyway in the limit its length going towards infinity? I mean, electrical field times length equals difference in potential, and if voltage remains constant while length diverges, then the electrical field must approach zero.
As the wire gets longer, the resistance R would increase, so to keep the current fixed at I, you'd have to increase the potential difference V. In the microscopic view, you'd have ##\vec{J} = \sigma\vec{E}##. Neither the current density nor the conductivity depend on the length of the wire, so ##\vec{E}## doesn't depend on the length either.
You're right that in a real wire, there'd be an electric field directed along the wire to keep the charges moving. You're supposed to use the approximation that this is an ideal conductor, so there's no resistance. Once the current is established, no electric field is needed to keep it moving.
Likes Nikitin
Related to Electric field in a cylindrical conductor
What is an electric field?
An electric field is a physical quantity that describes the influence that an electric charge has on other charges in its vicinity. It is a vector quantity, meaning it has both magnitude and direction.
How is an electric field created in a cylindrical conductor?
An electric field is created in a cylindrical conductor when there is a potential difference between the ends of the conductor. This causes the free electrons in the conductor to move and create an electric field.
What is the direction of the electric field in a cylindrical conductor?
The electric field in a cylindrical conductor is always directed radially outward from the center of the conductor. This means that the field lines will be perpendicular to the surface of the conductor at all points.
How is the strength of the electric field in a cylindrical conductor determined?
The strength of the electric field in a cylindrical conductor is determined by the potential difference between its ends and the distance between the ends. The larger the potential difference and the smaller the distance, the stronger the electric field will be.
What is the relationship between the electric field and the charge density in a cylindrical conductor?
The electric field and the charge density in a cylindrical conductor are directly proportional. This means that the greater the charge density, the stronger the electric field will be at a given point in the conductor.
  • Other Physics Topics
